ITR valves
Old Nov 6, 2004 | 08:28 PM
encognito's Avatar
Default ITR valves
Are OEM ITR valves(exhaust to be exact) any different from the GSR valves?
Old Nov 6, 2004 | 11:18 PM
SpdFrk's Avatar
Default Re: ITR valves (encognito)
Yes, ITR valves are lighter.
Old Nov 7, 2004 | 12:03 AM
98itr0448's Avatar
Default Re: ITR valves (SpdFrk)
I think one of them, either intake or exhaust is the same as gsr, but the other is lighter. Search would probably have some more detailed info on them though.
Old Nov 7, 2004 | 02:10 AM
JUNEK9's Avatar
Default Re: ITR valves (98Itr-0448)
The exhaust valves are the exact same...Onlt the intake valves have the benifit of being lighter. At least that is what the dealership told me.
Old Nov 7, 2004 | 05:21 AM
tuoniz's Avatar
Hmm. Are you contemplating buying some?
Old Nov 7, 2004 | 10:41 AM
ITR184's Avatar
I believe the the valve stems are a smaller Diameter on the ITR. Look up the part numbers and compare.
Old Nov 7, 2004 | 05:41 PM
encognito's Avatar
Default Re: ITR valves (tuoniz)
No, the machine shop i used for a valve job kept refering to my head as a gsr to the guy that was actually doing the work and my invoice says they worked on a "1.8 RSR ACCURA"
Old Feb 1, 2005 | 01:34 PM
Resident Evo's Avatar
Would a set of ITR intake valves make any more power in my b16 by replacing the stock b16 Si intake valves?
Old Feb 1, 2005 | 01:42 PM
Bbasso's Avatar
Lighter and more even weight between all of them.
there was something else I read a long time ago, but I forgot what it was
Old Feb 1, 2005 | 01:43 PM
MattD@Stoptech's Avatar
Default Re: ITR valves (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Lighter and more even weight between all of them.
there was something else I read a long time ago, but I forgot what it was </TD></TR></TABLE>
only on the intake side
Old Feb 1, 2005 | 01:52 PM
1GreyTeg's Avatar
"Bigger valves have their advantages, but are heavier. The Type R's valves were redesigned so as to have a bigger cone area, but still be 12% lighter."
https://honda-tech.com/zerothread?id=858874
https://honda-tech.com/zerothread?id=665351
https://honda-tech.com/zerothread?id=458443
Just like the X files,,, it's out there.
Old Feb 1, 2005 | 01:55 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: ITR valves (EBP-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP-Si &raquo;</TD></TR><TR><TD CLASS="quote">Would a set of ITR intake valves make any more power in my b16 by replacing the stock b16 Si intake valves?</TD></TR></TABLE>
probably a tad since the port stem area is thinner on intake side=more flow in.
ferio-ichi3
Sep 19, 2013 08:31 PM
hifi_civic
Aug 9, 2005 04:13 AM
AbaZ
May 10, 2004 03:37 PM
TRuST
Jun 16, 2002 10:48 AM
TRuST
Dec 10, 2001 06:20 AM
