vtec wiring
Old Nov 6, 2004 | 07:00 PM
eg6T's Avatar
Default vtec wiring
can anyone show me a diagram or explain which of the 3 vtec wires,red,black,blue i believe...which wire plugs up to which connector next to the distributor?thanks
Old Nov 6, 2004 | 07:22 PM
2lua's Avatar
Default Re: vtec wiring (eg6T)
what year is the car, motor or what kindna harness are you using?
Old Nov 6, 2004 | 07:29 PM
eg6T's Avatar
Default Re: vtec wiring (2lua)
93 civic hatch,b16, harness?
Old Nov 7, 2004 | 03:40 PM
eg6T's Avatar
anyone?
Old Nov 7, 2004 | 03:51 PM
2lua's Avatar
well those wires are close, but not close enough. if you have a meter then you can use it to ohm those wires and use it.
vtec soleniod = grn/yel = a4 at the ecu
vtec pressure switch = blu/blk = d6 at the ecu. the blk will go to ground.
Old Nov 7, 2004 | 05:44 PM
eg6T's Avatar
thanks man
Old Nov 7, 2004 | 05:46 PM
DJ_SaNdOz's Avatar
if your motor does not have a pressure switch, you can run the ecu wire for the switch to a ground. Just FYI.
It is better to get a pressure switch in the long term, but this will get VTEC working. Quite a few newer JDM motors didn't come from the factory w/ a pressure switch for whatever reason.
Old Nov 7, 2004 | 06:20 PM
eg6T's Avatar
Default Re: vtec wiring (DJ_SaNdOz)
cool thanks
hatchyboy89
Sep 17, 2011 09:02 AM
Gofmf
May 21, 2009 08:37 AM
skoodles2k6
Apr 14, 2008 07:29 PM
NSfit
Dec 29, 2006 12:17 PM
nutball72
Aug 26, 2006 10:54 AM
