Just finished B16a2 swap. First start question.
Is there anything special I have to do for the first start, like a way I need to prep. the oil pump? or do I just try firing her up?
Thanks.
Thanks.
Re: Just finished B16a2 swap. First start question. (fordSuck)
With everything hooked up right (oil, fuel, timing) it should start up just fine. Otherwise, it'll just die.
I hand crank it counter clockwise, than i unplug the dizi and crank it over for a while with the starter.
Re: Just finished B16a2 swap. First start question. (TwoKSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwoKSiR »</TD></TR><TR><TD CLASS="quote">I hand crank it counter clockwise, than i unplug the dizi and crank it over for a while with the starter. </TD></TR></TABLE>
anyways,
prime the fuel system a few times(put the key to on but dont start the engine)
just to get fuel up to the injectors to help it start a bit.
dont forget to get your ignition timing set proper once you get it running.
anyways,
:-\ no dice, turned over, but wouldn't start. Tried it a couple of times. Pulled off valve cover, and timing is def. in line...
any suggestions? I tried giving it a lil gas, and it seemed to take it, but still would stay running. seemed like it wanted to though
Re: Just finished B16a2 swap. First start question. (hondaeg8)
No check engine light, I have spark and I can hear fuel pump run.
Just doesn't seem to want to grab.
Would it be an issue that I lowered compression to 9:1 and upgraded injectors, but don't have turbo on it yet? or would it still start?
Is push starting a good idea...?
Bad coil in the distributor, at least that's what was wrong with mine. If you have a buddy with a spare dist. put it on your motor and see what happens. Worked for me.
Also, I just swapped coils from my d-series to my b-series dist and it works great now.
mynameizstitch
03-17-2012 10:55 AM
rollinhonda3
11-09-2010 02:25 PM
crxcess
06-10-2006 06:05 AM
