manual transmission removal problem
Old Nov 6, 2004 | 05:12 PM
Mercuryc2001's Avatar
Default manual transmission removal problem
I have all the trans bolts removed but I can't get it to come off the engine.
It wont budge at all.
Are there any tricks to getting the trans off the engine and/or break the seal!
I need Help!
Old Nov 6, 2004 | 05:16 PM
B2FiNiTY's Avatar
Default Re: manual transmission removal problem (Mercuryc2001)
Did you remove every bolt? Remove the starter? Axles?
If all the bolts are off, you can just shake it/kick it and it should pop off.
Old Nov 6, 2004 | 05:23 PM
deepgreengsr's Avatar
Default Re: manual transmission removal problem (B2FiNiTY)
there is no seal, just use a pry bar and some elbow grease.
Old Nov 6, 2004 | 05:27 PM
jdmotorsports's Avatar
there is like 1 or 2 bolts that are realy well hidden. they are a pain to get to. otherwise it should come off with no prob at all.
Old Nov 8, 2004 | 11:24 AM
Hey thanks people -
just finished cluch install
I forgot to remove the lower stater bolt!
oops!
Grampy Mike
Dec 30, 2010 11:20 AM
Twistedframe
Oct 5, 2007 05:44 PM
Rustynuts
Aug 1, 2007 05:44 PM
GarageAlchemist
May 25, 2006 03:04 PM
syndicate43
Nov 25, 2002 05:49 PM
