would you pull the motor if you had to replace clutch/flywheel & timingbelt/water pump?
Im contemplating whether I should pull the motor out to do the work I mentioned in the title. I dont have access to a lift and I want to do the work myself, tools accessible to me are the standard jack and jack stands. Should I pull it out?
quick Q. i have a GSR waterpump and possibly a GSR timing belt.
could i use that on an ITR if i needed to change the H20pump and belt? not so much the belt though, i could just get one from the dealer for an R.
but i have an extra GSR pump
Take out the driver's side engine mount and work on the timing belt/water pump (supporting the bottom with the jack).
Then reinstall the driver's side mount and drop your tranny. DO NOT remove the engine - way too much hassle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BubblesLovesHisPussys »</TD></TR><TR><TD CLASS="quote">Take out the driver's side engine mount and work on the timing belt/water pump (supporting the bottom with the jack).
Then reinstall the driver's side mount and drop your tranny. DO NOT remove the engine - way too much hassle.</TD></TR></TABLE> there is a smart guy there
Pull the fricken motor.
(NOTE: I have removed the motor from my car 5 times and reinstalled it 6 times in the last 18 months by myself. It gets easier everytime
I have removed the trans both ways (motor in the car and puled the motor) Fortunatly the honda tranny is light enough to unbolt, set-on you chest and "shimmy"out from under the car.
Pick your poison,
Mattj
Pick your poison,
Mattj
coot_er
Sep 15, 2005 09:20 AM
bboylito
Dec 16, 2004 04:26 PM
Volcom
Dec 28, 2002 10:50 AM
