bucking/bouncing idle problem... Can't figure it out
1991 CRX Si - Going any steady rpm, the car will buck... After the car gets warmed up, it has a bouncing idle. Won't go under 1000rpm, and won't go over 1300rpms... I put in a known good ignitor, and it did the same thing. Anyone have any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickofjdm »</TD></TR><TR><TD CLASS="quote">sound like a bad TPS....</TD></TR></TABLE>
I think that the TPS sensor broke when the motor mounts were so screwed up.
It was ziptied together for a while but if i remember right it was pretty trashed.
I totally forgot about that until just now.
I adjusted the TPS a couple weeks ago, because I was diagnosing another problem
. It was within specs, but that connecter does have me kind of worried... I'll check it out. Its off and on, but it keeps getting worse and worse.
No CELs, I used to get the TPS code a lot when I was getting on it. Ever since I checked it out, it hasn't popped up yet.
I have a spare TPS, I'll give it a try. Thanks for the help guys, anyone else have any suggestions??
. It was within specs, but that connecter does have me kind of worried... I'll check it out. Its off and on, but it keeps getting worse and worse. No CELs, I used to get the TPS code a lot when I was getting on it. Ever since I checked it out, it hasn't popped up yet.
TPS was bad. I put on my ZC throttle body until I can get the TPS changed out on my Si TB. I drove for two and a half hours just now and it did just fine. Thanks again for all the help guys!
Travis, I zip tied the TPS connecter back on there lol.
drummr6
Mar 17, 2007 04:10 PM
