GSR ecu w/ a B18C5
I'm looking at an EK with a B18C5 swap. The owner has a GSR ecu in it that he says he was using to save gas and not rag on the motor. He said he has a P28 he could include with the car.
Coming from a VW background, I was wondering what effects running a GSR ecu on a B18C5 would have. Is it going to just be less aggressive? Will the fueling be off? Is it a bad idea? How much, if any, power would be lost in a setup like this?
fueling and timing will be a little off, but the main con. is that vtec on the gsr ecu switches at 4400 rpms, its setup to work with the iab's from the gsr; the typr r has single stage im. so vtec set that low is prolly bogging the car at vtec crossover
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">fueling and timing will be a little off, but the main con. is that vtec on the gsr ecu switches at 4400 rpms, its setup to work with the iab's from the gsr; the typr r has single stage im. so vtec set that low is prolly bogging the car at vtec crossover</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude »</TD></TR><TR><TD CLASS="quote">crossover point is 5500, fuel and timing maps are alot more agressive</TD></TR></TABLE>
-PHiZ
-PHiZ
Tex Blackwell
Jul 14, 2004 05:25 PM
