02 sensor
Old Nov 5, 2004 | 07:49 PM
TRUTHUGSOULJAH's Avatar
Default 02 sensor
if the 02 sensor is bad what will happen or what will the engine do. thanks
Old Nov 5, 2004 | 07:52 PM
drdisco69's Avatar
Default Re: 02 sensor (TRUTHUGSOULJAH)
It will run poorly and get worse fuel mileage. If it's bad enough, you may get a check engine light.
Old Nov 5, 2004 | 07:56 PM
Default Re: 02 sensor (drdisco69)
thanks alot, thats wat i notice i get a check engine light and the fuel mileage is cut in half. all i smell is fuel when i am driving, so strong i have to drive with the windows open,....hopefully its the 02 sensor.
Old Nov 5, 2004 | 08:09 PM
drdisco69's Avatar
Have you checked the codes for the check engine light?
Old Nov 5, 2004 | 08:13 PM
i don't know how to check for the codes
Old Nov 5, 2004 | 08:23 PM
drdisco69's Avatar
What type of car is it?
Old Nov 5, 2004 | 08:25 PM
its a 93 hatch with a b16a2 motor.
Old Nov 5, 2004 | 11:49 PM
PrettyLude's Avatar
check the code like this, there is a jumper harness under the glove box, connect the two pin harness together, and read how many flashes the check light flashes
Old Nov 6, 2004 | 01:21 PM
Default Re: (PrettyLude)
thanks
hondapinellas
Aug 17, 2014 12:30 PM
anduhy
Jan 16, 2008 11:17 AM
civicex_88005
Jun 21, 2005 02:17 PM
93WhiteHatch
May 31, 2005 07:21 PM
JAYGSR
Apr 28, 2005 11:38 AM
