what clutch for a 95 ex
Old Nov 5, 2004 | 06:17 PM
SFrogue85's Avatar
Default what clutch for a 95 ex
I was wondering if anyone could help me out...I am looking to get a new clutch and possible flywheel set up. i was thinking ACT or Exedy, if anyone could help me out it would be much appreciated.
Old Nov 5, 2004 | 06:43 PM
b20vtecEK's Avatar
Default Re: what clutch for a 95 ex (SFrogue85)
clutchmasters retains stock pedal feel, thats my first choice always.
Old Nov 5, 2004 | 07:35 PM
DOHC_EG6's Avatar
i have a clutchmaster 6 puck with spring. i used to have a act 6 puck. the thing with act you get chatter with so i got the clutchmaster with spring. the chatter was gone with just very little diference in grip. if you want to get a flywheel i sugest you get a fidanza. its really good i got the 9lbs.
Old Nov 5, 2004 | 07:41 PM
smart monkey's Avatar
I sell act and exedy and am in your area. I like the exedy for the money. good stuff
boostedcivicsir's Avatar
Mr. Badwrench
if it is basically stock a cm stage 1 with a flywheel is great. for bolt ons, a stage 2 is great. stage 3 is where you get into spray and 4 for a turbo. i have done many stage 2 /3 with flywheel combo's. the stage 2 with a flywheel should suit you fine.
Old Nov 5, 2004 | 09:02 PM
Del Sizzle's Avatar
If you are under 150hp. A Exedy stage 1 set up should be good enough.
Old Nov 5, 2004 | 09:29 PM
SFrogue85's Avatar
I plan to eventually get a turbo. Run around 7psi, will those clutches work?
Old Nov 5, 2004 | 09:32 PM
Del Sizzle's Avatar
Default Re: (SFrogue85)
Yeah, but Go with a stage 2 or 3 if you're going turbo.
Old Nov 6, 2004 | 05:36 AM
tommyz32's Avatar
if u plan to get turbo, im running ACT HD/SS in a d16z6 and its holding just fine
Old Nov 6, 2004 | 05:24 PM
JDMNICA's Avatar
Default Re: what clutch for a 95 ex (tommyz32)
i would go with exedy cuz its got good quality and a good reputation
Old Nov 6, 2004 | 05:34 PM
DeadVet's Avatar
Default Re: what clutch for a 95 ex (JDMNICA)
Im running a spec stage 4 with my soon to be turbo setup at 15-20psi. I used a spec stage 3 in my focus making 220whp and it held up great. I would turn the boost up to 18psi at the track making close to 300 and it never slipped. The spec clutches are reasonably priced too. I got my stage 4 for 309.
Old Nov 6, 2004 | 06:11 PM
Calvinator's Avatar
I'm running a xtreme PP w/ SS disc and i love it. The pedal is slightly harder, but the grip and the drivability is great.
Duck Sauce
May 18, 2008 10:43 AM
lkailburn
44
Sep 28, 2004 12:02 PM
-=TWITCH=-
Apr 17, 2002 08:25 AM
The Punisher
Oct 19, 2001 07:50 PM
