Which Clutch and why?
Old Oct 17, 2001 | 07:04 PM
The Punisher's Avatar
Default Which Clutch and why?
I am ditching the ACT I have with 2000 miles on it for a new one. I am trying to decide between these three, so help me out fellas. Just to give you a little about my setup, I will be running a turbo with 450-500 whp (Hopefully!) The reason I am going away from ACT is I just had two buddies with LS's that pulled their ACT's and I saw what it did to the flywheel. It was horrible, I am sure plenty of people have them and are fine with the results that are produced, but I just bought that lightweight flywheel. After what I saw done to the factory flywheel, I don't want to mess up the lightened one I just got! Post what you can, I am buying in a few days.
Old Oct 17, 2001 | 10:20 PM
Mike95lude's Avatar
Default Re: Which Clutch and why? (gsr*lude)
well Clutch Masters Stage 3 will NOT hold up to that kinda power...You are going to need a very strong pressure plate and a pucked disk....a full face disc won't be good for that kinda power. So I voted CM Stage 4....I bet the Clutchnet stage 3 would be a good choice too.
Old Oct 17, 2001 | 11:25 PM
VeeTec's Avatar
I've had two CM stage 3's and I also had 2 CM flywheels.
My stage 3 would only last about 3K miles. I eventually had to go with a stage 4, four puck ceramic disc. I also ended up swapping my first CM flywheel for a new one because the center of the flywheel started to meltdown.
The new one has a bearing in the center that prevents this from happening.
The stage 4 does let out a bit sudden and harsh though, but it was holding the power.
Old Oct 18, 2001 | 07:30 AM
str8rcn's Avatar
Default Re: Which Clutch and why? (VeeTec)
I also use a stage 4 CM and the flywheel and it is great.Takes a little getting used to but streetable.I do have a question for some of you that have had a stage 4 longer.I have only had mine for about 6 months with no problems but have heard of some concern with the seals on the slave cylinder.Anyone had any problems?
Old Oct 18, 2001 | 07:38 PM
John's Avatar
New User
Default Re: Which Clutch and why? (str8rcn)
Why are we focusing on CM? Why not ACT or ClutchNet?
Old Oct 18, 2001 | 09:54 PM
Default Re: Which Clutch and why? (DunReit)
Well, I put a poll up for ClutchNet, and no one has said too much about it. I know there are some other companies like, Clutch Specialties that are good. ACT is ok, but I have been hearing very bad things lately, and I have seen two factory flywheels that are just hammered by the ACT. There is a spot to add to the poll, I left it open so other people could post their choice and why they like or dislike it.
Old Oct 19, 2001 | 04:47 AM
John's Avatar
New User
I'm quite suprised to see that considering I know about a half dozen people who have had trouble with their CMs...
Old Oct 19, 2001 | 04:13 PM
Well, have them post what problems they are having. And also have them post what their setup is, and what clutch they moved on to.
Old Oct 19, 2001 | 07:50 PM
illusion's Avatar
ive never heard a bad thing about Exedy (spelling?)
Thee_Antic
Oct 25, 2011 02:01 AM
Ls_Turboteg
Sep 7, 2008 11:01 PM
-=TWITCH=-
Apr 17, 2002 08:25 AM
