~~NEED HELP!!!~~
ny check engine light went on but i dont know whats wrong. i did a visual check and all the fluids and wires and stuff are still ok. i tried to dis connect my battery for 10 mins and even took out the ECU chip but the check engine light still came on.
Does anybody have or know a trustworthy mechanic i can maybe use or borrow in the west LA area?? shops are too expensive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">just reset it.. there is a little bottom under the steeringwheel for reset it</TD></TR></TABLE>
the maitanence reqd light and CEL are different
find out what code you are throwing..u can figure out by going here http://www.c-speedracing.com/faq/03.php
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMIEL »</TD></TR><TR><TD CLASS="quote">that little reset button is for the maintenance required light. thats not on. the chk engine light is. thanks tho. </TD></TR></TABLE>
my bad..for some reason, i thought its ur maintenance required light..
https://honda-tech.com/zerothread?id=978933
sticky on the top. that says ECU AND ABS CODES HERE!
