Top 10 ten things to check if your Accord won't start ??
Old Nov 5, 2004 | 11:59 AM
89dxhunchback's Avatar
Default Top 10 ten things to check if your Accord won't start ??
Ok, maybe ya can't think of 10, but suggestions are welcome. My car is a 94' with 92K miles. Got in a VERY minor wreck ( radiator, hood, radiator support ) and now won't start.
getting fuel ( hear the fuel pump kick on, and wet plugs )
weak ( IMO ) spark at the end of the spark plug, but its there
compression test and timing check tonight.
No ECU codes
Checked all fuses in the car and under the hood
Modified by 89dxhunchback at 10:04 AM 11/14/2004
Old Nov 5, 2004 | 12:33 PM
KatyHonda's Avatar
Default Re: Top 10 ten things to check if your Accord won't start ?? (89dxhunchback)
Check distributor cap and rotor for cracks. Check ignition coil resistance against specification w/ a good Volt-Ohm meter. If all those check out, pull the ignitor and have it checked. If you're not getting rpm indications during cranking, the coil or ignitor is likely.
Make sure plugs are cleaned and gapped correctly. Spark plug wires should be in good condition (check resistance).
good luck
Old Nov 7, 2004 | 07:27 AM
AllmansDB8*'s Avatar
Definitly check your igniter, and if it's not the igniter, check the coil...
Old Nov 7, 2004 | 07:30 AM
bodiez's Avatar
Hit the floor!
Default Re: Top 10 ten things to check if your Accord won't start ?? (AllmansDB8)
Yeah def check for spark. If not work back from there.
Old Nov 9, 2004 | 07:38 PM
accordy's Avatar
Default Re: Top 10 ten things to check if your Accord won't start ?? (bodiez)
wiring to battery (Place where you would jump start).
It happened to me once , wires were loose
Old Nov 11, 2004 | 11:15 AM
Default Re: Top 10 ten things to check if your Accord won't start ?? (accordy)
I tested my coil on a friends 97 accord, and the coil is good, his dizzy is OBD2, so we couldn't test that, I'll see if I'm getting any RPM reads while cranking.
Thanx for the great tip.
I replaced the entire valve cover gasket set, new plug wires, new NGKs, and cleaned the rotor button, but it still didn't crank.
Old Nov 11, 2004 | 12:08 PM
marinakorp's Avatar
Check for GAS in the car
Is there an ignition cut off for an alarm?
Is the starter turning over?
Old Nov 11, 2004 | 10:12 PM
Default Re: Top 10 ten things to check if your Accord won't start ?? (marinakorp)
It has gas...
It doesn't have an alarm ( I installed them for 2 years at best buy )
The starter turns over the engine, it just doesn't start...
Old Nov 12, 2004 | 12:23 AM
I guess its the ignitor, since I tested my coil on a friend's car and it was fine, and I'm NOT GETTING ANY MOVEMENT FROM THE TACH while cranking on it...
How would I go about testing the ignitor ???
Old Nov 12, 2004 | 03:23 PM
KatyHonda's Avatar
Pull the igniter and take to auto parts store w/ a tester. Many have them.
good luck
Old Nov 12, 2004 | 04:20 PM
blkmrkt's Avatar
make sure there isnt a ***** in your intake
Old Nov 13, 2004 | 12:20 AM
Default Re: (4drcord)
I said top TEN things !!! Not top NINTY-NINE !!
I guess checking the intake for a ***** would be number fifty or so...
Wow, I didn't think autoparts guys even know what an ignitors look like !!!
Old Nov 13, 2004 | 05:25 PM
Default Re: (89dxhunchback)
Well... I swapped an ignitor from my civic in ( same part # on it ), and it still didn't run...
I swapped in some new gas... Still didn't run....
Tried both firing orders in the "Hayes manual" ( sucks BTW ) ( and yes, it listed 2 different firing orders on different pages... )
We killed 3 batterys trying to get it to start....
Finally my friend turned the dizzy about 75-degrees in the "retard" direction, and it started and reved fine !!! I'm going to make a new thread about what still needs to be done to fix it, but I'm pretty happy it runs fine...
Thanx to all the people that took the time to help me out.
94' accord, total cost ??? $563.00 !!!!
Old Nov 14, 2004 | 04:12 AM
KatyHonda's Avatar
You may have installed the distributor in backwards (w/ key upside down). It's supposed to be impossible, but isn't. Guess how I know
You need to remove the distributor and turn the key 180 degrees, if that's the problem.
The key has a slightly smaller width on one end which is supposed to prevent incorrect installation, however the width difference is so small that it is difficult to visually determine which is narrow/wide end of the key. The trick is the key should engage w/ no effort. If you forced the key into engagement, you may have damaged some distributor an internal sensor bracket. That's what happened to me. I had to remove distributor, disassemble and straighten the sensor mounting bracket.
good luck
Old Nov 14, 2004 | 06:04 AM
Default Re: (KatyHonda)
Thanx for the advice, but I know about the key ( I found out about the same way you did, but it was on my civic when I converted it to MPFI about 3 years ago ). I'm 150% sure that's not it.
Hopefully I'll do the timing belt today ( needs done anyway ), dispite the idea that I'm going to have to work about 11 hours tonight at work ( ummmm warehouse work ).
tree fingers
Aug 4, 2009 11:58 AM
johnls
Jun 26, 2007 09:35 AM
rdssk8rcs1
Jun 5, 2006 04:13 PM
hagrid
Nov 25, 2002 03:27 PM
Big_b_69er
Jan 24, 2002 09:07 AM
