How to pull check engine codes in an element.
Old Nov 5, 2004 | 05:01 AM
thehondaguru's Avatar
Default How to pull check engine codes in an element.
figured this would be the best place to try and figure it out. Anyone know. I am a do it your self person and WILL NOT take it anywhere to just have the code pulled.
Default Re: How to pull check engine codes in an element. (95 lude)
I wouls apreciate any inputs any of you may have since the element is pretty new and not many people have them.
Old Nov 6, 2004 | 11:12 AM
nobody knows?????
Old Nov 6, 2004 | 01:00 PM
PHiZ's Avatar
I don't know if you can make the dash CEL blink the codes, so I'd just go to AutoZone and have them slap an OBD2 code reader on it.
-PHiZ
Old Nov 6, 2004 | 01:20 PM
Default Re: How to pull check engine codes in an element. (PHiZ)
hmm that sucks. I wonder if I can buy a code reader my self?? Anyone know of any?
Old Nov 6, 2004 | 05:37 PM
PrettyLude's Avatar
the better ones on the market are from snap on and mac, the ones from autozone or o'reilly's will only get u in the right ball park.
the ones from autozone cost anywhere from 150 to 300, whereas, the ones from snap on and mac can cost up to 5000
Old Nov 6, 2004 | 06:04 PM
Default Re: (PrettyLude)
damn. I am better off getting a hondata or AEM EMS and just using that as a diagnostics tool.
Old Nov 6, 2004 | 07:19 PM
Slow98sedan's Avatar
Default Re: (95 lude)
The money you spend on hondata or AEM EMS you could easily buy a "decent" code reader. I just picked one up for just over $100 last night. Works just fine.
..adam..
Old Nov 6, 2004 | 07:21 PM
eg6T's Avatar
Default Re: (Slow98sedan)
the snap on one cost $13,000..i used it,it basically does the job for u
Old Nov 6, 2004 | 08:10 PM
drdisco69's Avatar
Default Re: (eg6T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">the snap on one cost $13,000</TD></TR></TABLE>
to that, the real ******* Honda ones are $2000 for the shitty one and $5000 for the touch screen HDS...
Old Nov 6, 2004 | 08:20 PM
PrettyLude's Avatar
i believe the best one on the market is the techmaster, which is 23,000
Old Nov 6, 2004 | 08:48 PM
eg6T's Avatar
Default Re: (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">
to that, the real ******* Honda ones are $2000 for the shitty one and $5000 for the touch screen HDS... </TD></TR></TABLE>
to you, douche http://www.autods.com.ua/shop/Modis-001.html
Old Nov 6, 2004 | 09:02 PM
Default Re: (eg6T)
ok so basically I am right, Correct? I mean If I spend like 350 on a hondata then add dattalogging I will be able to read check engine codes from there right??? So to me that is alot cheaper and it will be acurate!
Old Nov 6, 2004 | 09:12 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 lude &raquo;</TD></TR><TR><TD CLASS="quote">figured this would be the best place to try and figure it out. Anyone know. I am a do it your self person and WILL NOT take it anywhere to just have the code pulled.</TD></TR></TABLE>
You can either buy an OBD2 code reader, (ive seen them for less than $50) or you can jump pins 4 and 9 on the DLC and count the CEL blinks.
Old Nov 6, 2004 | 09:15 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 lude &raquo;</TD></TR><TR><TD CLASS="quote">ok so basically I am right, Correct? I mean If I spend like 350 on a hondata then add dattalogging I will be able to read check engine codes from there right??? </TD></TR></TABLE>
Nope, those systems can't display trouble codes as far as I know.
Old Nov 6, 2004 | 10:43 PM
vtekstorm's Avatar
Default Re: (Chiovnidca)
hey dude its a honda element with a warrenty. y dnt u just bring it to a dealer have them pull the code for you and fix the problem. it aint gonna even cost you anything cuz it should be under warrenty. other than that the snap on one works good but the real good one for honda is the hds. but good luck to you
Old Nov 7, 2004 | 04:25 AM
Default Re: (vtekstorm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekstorm &raquo;</TD></TR><TR><TD CLASS="quote">hey dude its a honda element with a warrenty. y dnt u just bring it to a dealer have them pull the code for you and fix the problem. it aint gonna even cost you anything cuz it should be under warrenty. other than that the snap on one works good but the real good one for honda is the hds. but good luck to you </TD></TR></TABLE>
HMM Its a honda element without a waranty because its a 2003. And I dont let ANYONE work on my cars because if something goes wrong I have only to balme myself.
This is my first newer car. I have always delt with 95 and newer, but I am a little older so I like something a little newer.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
So where can I get one of these??
Originally Posted by Chiovnidca
You can either buy an OBD2 code reader, (ive seen them for less than $50) or you can jump pins 4 and 9 on the DLC and count the CEL blinks.</TD></TR></TABLE>
Ok now I feel stupid asking, but what is the DLC, and where can I find it?
Old Nov 7, 2004 | 06:03 AM
PHiZ's Avatar
Well no matter what, one of your first investments needs to be a Helms manual. And that would have answered this question by now.
A sub $100 OBD2 code reader from autozone will work. But it won't get some vendor propreitary information, and it won't measure engine paramaters, it will just pull codes.
-PHiZ
Old Nov 7, 2004 | 06:58 AM
Default Re: (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">Well no matter what, one of your first investments needs to be a Helms manual. And that would have answered this question by now.
-PHiZ</TD></TR></TABLE>
WERD
Old Nov 7, 2004 | 07:01 AM
drdisco69's Avatar
Default Re: (eg6T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote"> to you, douche http://www.autods.com.ua/shop/Modis-001.html
I don't get it, thats just a more expensive tester that does pretty much the same stuff the Honda HDS does, but for twice the money. to that, and to calling people names.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 lude &raquo;</TD></TR><TR><TD CLASS="quote">HMM Its a honda element without a waranty because its a 2003. And I dont let ANYONE work on my cars because if something goes wrong I have only to balme myself.</TD></TR></TABLE>
Why would a 2003 not have a warranty? You have 3 years, unless you have an assload of miles. And the whole reason for the warranty and making someone else do it is because then you have someone else to hold responsible. Trust me, because of the warranty survey you'll get about the work performed, they really want to fix it right the first time. And it will be free, becase not only is it under the 3 year warranty, being a check engine light means it's probaby under the 8 year federal emmisions warranty. I'm not telling you to not do stuff yourself, it's great that you do. But there are some times when you can sit on your duff and watch other people do things, and I would take advantage of that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 lude &raquo;</TD></TR><TR><TD CLASS="quote"> what is the DLC, and where can I find it?</TD></TR></TABLE>
The DLC is the data link connector, which is the diagnostic port used to pull the codes stored in the computer. On the Element it should be located under the drivers side of the dash. It's a grey trapeziod shaped connector.
Old Nov 7, 2004 | 08:45 AM
hey man thanks alot. I apreciate it. I will make up my mind some how.
Old Nov 7, 2004 | 02:01 PM
vtekstorm's Avatar
how many miles do u have on the element. cuz if its an 03 there should still be a warrenty on it. if not how come u didnt get an extended.and if its out of warrenty have honda pull the code out. and u replace the part yourself. it would sill be cheaper than buying yourself a scan tool and doing it yourself. just a thought
jwagner
Engine Management and Tuning
Apr 8, 2012 07:38 PM
GriFFIthS
Honda Civic (2001 - 2005)
Feb 21, 2011 04:26 AM
tecnic1
Nov 25, 2006 07:36 AM
Austin
Jul 16, 2006 05:16 PM
tz-devil77
Jan 21, 2003 12:37 PM
