YS1 Tranny...Short geared, long geared, what is it?
Old Nov 4, 2004 | 08:59 PM
MrHockney's Avatar
Default YS1 Tranny...Short geared, long geared, what is it?
I just got a B16 swap and it came with a YS1 tranny. I have been told that it is a good drag tranny, but i cant find any info on it. Specs would be great. But any kind of help would be great.
Old Nov 4, 2004 | 09:23 PM
Kataku2K3's Avatar
Default Re: YS1 Tranny...Short geared, long geared, what is it? (MrHockney)
What you have is most likely a '92-93 GSR tranny which does have the tightest gearing of all the cable trannies. It really depends on your setup, NA, FI, etc. as to what it works with best. If your just sticking to a simple all motor setup then it should work fine. It can/will work great for high boost turbo setups as well but there's many more things to bring into consideration (how high you'll be reving, size slick, and your target trap mph). Just my $0.02
Old Nov 4, 2004 | 10:08 PM
TEAMGENDAI's Avatar
Default Re: YS1 Tranny...Short geared, long geared, what is it? (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">What you have is most likely a '92-93 GSR tranny which does have the tightest gearing of all the cable trannies. It really depends on your setup, NA, FI, etc. as to what it works with best. If your just sticking to a simple all motor setup then it should work fine. It can/will work great for high boost turbo setups as well but there's many more things to bring into consideration (how high you'll be reving, size slick, and your target trap mph). Just my $0.02</TD></TR></TABLE> This is absolutely correct. But be careful some YS1 came on ls integra's 92-93. Good luck
Old Nov 4, 2004 | 10:38 PM
Kwuaymaikrup's Avatar
Are you sure? Mine is a JDM cable trans that came on a JDM B16 swap and I swear it is tighter than the 92-923 GS-R trans. I am pretty sure my trans has the same gearing as the Type R trans. I am not sure what the code is for my trans since the sticker is missing. I don't know "for sure" but I just wanted to throw this out there.
Old Nov 4, 2004 | 10:44 PM
Kataku2K3's Avatar
Default Re: YS1 Tranny...Short geared, long geared, what is it? (Kwuaymaikrup)
Ryan just from what I've personally seen it's the tightest cable tranny (that's the the gear ratios basically show too). I have also heard of the YS1 as a common name for DOHC cable trannies which also opens the possibility of getting a nonVTEC one. On Mike's car we've used them all, Y1, J1/S1, just playing with the cruising rpm on the freeway the YS1 has you wound up the highest in 5th at a given mph. As for the cable trannies, we know they suck on high hp setups anyway, you'll soon have a hydro S4C!
Old Nov 4, 2004 | 10:55 PM
Good info as always Adam. You are smarter than I thought
Old Nov 4, 2004 | 11:13 PM
Moto TO4ELSVTEC's Avatar
Here is a link to a spec chart for trannies, hope this helps.
http://www.allmotorhonda.com/t...s.htm
unrivaledintegra
May 25, 2007 10:39 AM
Part1
12
Feb 9, 2005 10:19 AM
RICE POLICE SIP
Dec 28, 2004 05:09 PM
jdmb16a hatch
27
Sep 22, 2004 12:25 PM
g2turbo
Aug 6, 2003 05:28 PM
