carb questions...
Old Nov 4, 2004 | 06:54 PM
lsrex212's Avatar
Default carb questions...
ive searched and i have not found what im looking for...if someone else has agood link that may help please post....
i understand that carbs will atomize fuel a bit more effeciently, will that allow me to run a higher compression ratio using pump gas?...
im investigating a possible build with a b18a1 motor, crower 404's, a weber dcoe kit and it will be a street driven car...target redline will be 8000rpm and it will stay as 81mm bore with stock stroke and r/s ratio....will this be possible on 13.0-1 compression? or even 12.0-1 compression? any help will be appreciated...
i know this sounds like a noob question, because i am a noob when it comes to carbs and also serious engine tuning...just trying to learn something so keep the posts on track with tech info...thanks....
down_the_hatch
37
Mar 30, 2011 07:36 PM
chadwick67
Nov 13, 2007 03:02 PM
90da4dr
Mar 9, 2003 05:18 AM
Racer X
Oct 18, 2002 11:28 AM
