thread note for shift knob
Old Nov 4, 2004 | 05:44 PM
transmission11's Avatar
Default thread note for shift ****
hey guys, im currently making a type-r shift **** (on the lathe) in one of my metals classes. I was just wondering if anyone knew the inside diamter and thread note to a stock shift **** on an ek. I just need to know what to tap it out to so it fits on a shifter. Thanx
-matt
Old Nov 4, 2004 | 06:06 PM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: thread note for shift **** (transmission11)
Firstly, it's called a thread pitch, and diameter
and as a guess, it'll be an m12 X 2.5
Clayton
Old Nov 4, 2004 | 07:37 PM
Default Re: thread note for shift **** (Clayton)
thread note refers to the series. but thanx anyways
Old Nov 5, 2004 | 04:57 AM
Sobe_Death's Avatar
i thought honda shifter threads were tapered?
Old Nov 5, 2004 | 08:05 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: (Sobe_Death)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sobe_Death &raquo;</TD></TR><TR><TD CLASS="quote">i thought honda shifter threads were tapered?</TD></TR></TABLE>
Nope, not that I know of.
Old Nov 5, 2004 | 12:54 PM
Sobe_Death's Avatar
well why do they always rattle around inside the shift *****?? even the thread on ones do, and it is kinda annoying
Old Nov 5, 2004 | 01:07 PM
H-T Order of Merit
The reason they "rattle" is because the internal threads aren't the same size as the external threads. The internal threads, the ones inside the ****, are slightly bigger than the threads on the shift lever. The ones that are probably going to rattle more are the metal ones. The plastic ones can be made to a closer dimension so when you thread the **** on the shift lever it kind of cuts/forms the plastic to match closer so it doesn't rattle. If you were to try that one metal ***** it would just get stuck and not go on any further.
Old Nov 5, 2004 | 05:54 PM
Default Re: (TouringAccord)
i agree, if you use too soft of a metal and such a close fit, theyll just strip.
Old Nov 5, 2004 | 09:31 PM
Clayton's Avatar
H-T Administrator
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by transmission11 &raquo;</TD></TR><TR><TD CLASS="quote">thread note refers to the series. but thanx anyways</TD></TR></TABLE>
WOW!!!....
care to explain this?? I mean...WTF do I know...I only make my living manufacturing objects with threads
Clayton
Old Nov 7, 2004 | 06:31 PM
cjames235's Avatar
bump cus id like to know also
Old Nov 9, 2004 | 04:24 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: (transmission11)
Did you figure it out yet???
Platinum.Skillz
Oct 17, 2007 03:45 PM
91ed9
Apr 12, 2007 01:24 PM
8k-red-DC2
Apr 2, 2005 09:37 AM
payneth
Feb 1, 2004 01:29 PM
Kool Blue Lude
Sep 7, 2003 10:47 PM
