Brake Swap?
Old Nov 4, 2004 | 04:14 PM
EriK20's Avatar
Default Brake Swap?
I am doing an itr brake swap for my eg for front brakes and gsr rears. I was wondering if i would need the proportiong valve?
I have already the gsr rear brakes completly assembled and the itr rotor and calipers gsr front spindles, brake booster, master cylinder
i still have to get the ebrake cables and lines
also is there anything else i would need?
thanx
Old Nov 4, 2004 | 04:37 PM
chad's Avatar
Moderator
Default Re: Brake Swap? (blucivicsi99)
you aren't doing an ITR brake swap!!! itr brake swap is 5 lug....
Old Nov 4, 2004 | 05:13 PM
boostedcivicsir's Avatar
Mr. Badwrench
some say you need a prop valve and master cylinder and some say you dont. me i say if you are converting to rear disc, you need a rear disc prop valve. the brake bias is not correct if you dont. i have my stock si master cylinder on an itr 5 lug swap stops fine. i would do a prop valve as well. and just curious, the itr fronts are they 5 lug? and you have a 4 lug rear? just wondering why?
Old Nov 4, 2004 | 05:23 PM
EriK20's Avatar
Default Re: Brake Swap? (chad)
Chad its eric i know im not doing an itr swap i was in a hurry
Old Nov 4, 2004 | 05:25 PM
EriK20's Avatar
Default Re: Brake Swap? (boostedcivicsir)
i am getting the itr rotors drilled to 4x100
Old Nov 4, 2004 | 05:28 PM
EriK20's Avatar
Chad what would u say about the prop valve. i know u havent said anything to me about it when we talked i figured if i did u had just forgot and was going to ask u when i called tomorrow but i decided to post up. but i looked up a how to on here and the guy that did it said something about it so i was just wondering
by the way like the new race car reminds me of my old car
Old Nov 4, 2004 | 06:08 PM
chad's Avatar
Moderator
i didn't put it on my car....
chad's Avatar
Moderator
K SERIES EG.....that should help you forget your old car!!!
Old Nov 4, 2004 | 06:09 PM
3.point.2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">you aren't doing an ITR brake swap!!! itr brake swap is 5 lug....</TD></TR></TABLE>
not if its a 96 or 97. i think ones of those years was 4 lug
Old Nov 4, 2004 | 06:28 PM
chad's Avatar
Moderator
Default Re: Brake Swap? (h23eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23eg &raquo;</TD></TR><TR><TD CLASS="quote">
not if its a 96 or 97. i think ones of those years was 4 lug</TD></TR></TABLE>
4x114.3.....not 4x100
haha
Old Nov 4, 2004 | 07:08 PM
EriK20's Avatar
what ever i really dont care J/K
hey where can i get those drilled?
Old Nov 4, 2004 | 07:14 PM
EriK20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">K SERIES EG.....that should help you forget your old car!!!</TD></TR></TABLE>
That is true
Old Nov 4, 2004 | 07:16 PM
lumpbuzcut's Avatar
noobie question. Whats the big deal with 5 lug?
Old Nov 4, 2004 | 07:20 PM
Mr. Badwrench
Default Re: Brake Swap? (lumpbuzcut)
not many eg's with 5 lug, something to set apart from others. there are only 2 others in delaware that i know of. other than me.
Old Nov 4, 2004 | 07:25 PM
lumpbuzcut's Avatar
so it's not for anything but setting it apart from the rest? That's what I thought, it's just an extra lug, not like it add's 20 hp.
56killa
12
Jun 4, 2018 02:26 PM
boostedb20ek
Apr 12, 2009 10:55 PM
kpop
Feb 7, 2007 12:32 AM
WHITE DEATH
Jul 5, 2006 10:12 PM
SpecR_EK
Aug 21, 2001 11:43 AM
