Found water inside the car
Old Nov 4, 2004 | 01:37 PM
swapped's Avatar
Default Found water inside the car
its been rainin quite a bit around here and i went outside today to find the passenger side of my integra's floor soaked, and better yet i saw a stream of water coming from under the glovebox, when i turned the car on however it seemed that the stream went away, or the leak stopped, any ideas on what this is? thanks.
Old Nov 5, 2004 | 04:21 AM
JimBlake's Avatar
Default Re: Found water inside the car (swapped)
What year? In my 3rd-gen, there's a drain hose coming off the bottom of the AC housing. It's right above the passenger footwell, way forward where you can kick it with your toes. Is it disconnected?
If that's not it, maybe a leaking seal at the windshield cowl?
Old Nov 5, 2004 | 01:19 PM
swapped's Avatar
Default Re: Found water inside the car (JimBlake)
it's a 92 RS yea it was leaking from way forward in the passenger cowl, that could be it i'll have to check that, but would it happen when its raining and the car is not running?
408bagged
Feb 3, 2011 05:58 PM
VSG
Dec 17, 2008 04:35 AM
Mayorseed
Nov 1, 2007 04:51 AM
DeadVet
Apr 7, 2005 05:44 PM
TwistedHatch
15
Dec 4, 2003 07:11 AM
