vacuum to the map sensor 89 crx si with a b16
Old Nov 4, 2004 | 12:13 PM
Cractos's Avatar
Default vacuum to the map sensor 89 crx si with a b16
I need a picture of how to hook up all the vacuum hoses....
Old Nov 4, 2004 | 12:20 PM
Reelizmpro's Avatar
Default Re: vacuum to the map sensor 89 crx si with a b16 (Cractos)
It goes to nipple on top of the throttle body.
Old Nov 4, 2004 | 12:24 PM
Cractos's Avatar
Default Re: vacuum to the map sensor 89 crx si with a b16 (Reelizmpro)
i need...to know the other lines also...like the whole back firewall....for the most part...my friend messed them up....and now the car runs like ****
Old Nov 4, 2004 | 10:12 PM
Cractos's Avatar
bump
Old Nov 5, 2004 | 02:07 PM
Cractos's Avatar
bump can someone help me
Old Nov 5, 2004 | 02:12 PM
drdisco69's Avatar
Default Re: (Cractos)
There should be a sticker under the hood, if it's original. You can use that diagram to figure out where everything needs to go.
Old Nov 8, 2004 | 08:08 AM
Cractos's Avatar
i need a pic of a crx with a b16 to see the vacuum to the map sensor and the other to things next to the map sensor
Old Nov 8, 2004 | 11:33 PM
Cractos's Avatar
bump
Old Jan 17, 2005 | 03:43 PM
teler86's Avatar
need help with the same thing, if you find a pic tell me
sleep_Rx
Dec 2, 2007 04:43 PM
importgod21682
Oct 9, 2006 11:23 AM
DC 2
Mar 9, 2004 07:00 AM
T_Rex
May 14, 2003 04:06 PM
kangjin
Dec 8, 2001 10:49 PM
