Trans swap!!!
Old Nov 4, 2004 | 11:19 AM
Integ-boy's Avatar
Default Trans swap!!!
I have a 2000 gsr and plan to make it a street/circuit car now what would be the best transmission for that.
1. stock gsr trans with LSD
2. Civic si trans
3. Civic si trans with LSD
4. type R trans
i have heard that the Si transmission has great gear ratios, with an LSD could it be better than a type R trans.
P.S. what is a good aftermarket LSD for any of those trans
Old Nov 4, 2004 | 11:37 AM
iBear's Avatar
Default Re: Trans swap!!! (Integ-boy)
either B16 or Type R tranny
Old Nov 4, 2004 | 11:47 AM
LSvtec03's Avatar
Default Re: Trans swap!!! (EJellyfish1)
the si/b16 is the same gearing as the type r, just no lsd and the type r comes with some stronger internals. quaiffe and kaaz i hear make good lsds. also obx makes one that i hear is pretty good. i think you should be the guinea pig and try it out for us.
might wanna look into a 4.7 final drive while you're at it.
Old Nov 4, 2004 | 01:35 PM
94gsr_vtc's Avatar
Default Re: Trans swap!!! (LSvtec03)
no the b16 with a type r lsd would be the exact same thing as a type r tranny. not stronger internals or anything. if i were you i would just find a type r tranny
Old Nov 4, 2004 | 02:12 PM
LSvtec03's Avatar
Default Re: Trans swap!!! (94gsr_vtc)
no, it definitely comes with stronger something. synchros, i think.
Old Nov 4, 2004 | 02:41 PM
batmang yO!
Guest
Posts: n/a
uhhhh, someone correct me if im wrong, but why would you want LSD on a track/circuit car? I understand if its a drag car then LSD would be ideal.
LSD would make cornering a bitch.
LSD = Positive traction, equal power to both drive wheels weather turning or going straight.
...mabey i've been sniffing too much gasoline?
Old Nov 4, 2004 | 02:51 PM
.RJ's Avatar
.RJ
Default Re: Trans swap!!! (ninetee7Gee-***-Arrrrrrrr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninetee7Gee-***-Arrrrrrrr &raquo;</TD></TR><TR><TD CLASS="quote">uhhhh, someone correct me if im wrong, but why would you want LSD on a track/circuit car? I understand if its a drag car then LSD would be ideal.
...mabey i've been sniffing too much gasoline?</TD></TR></TABLE>
You're 100% wrong.
Old Nov 4, 2004 | 03:17 PM
gsrboi80's Avatar
Default Re: Trans swap!!! (.RJ)
Type R tranny and a b16 are the same except for no lsd in the b16 and longer final drive in the type r tranny
Old Nov 4, 2004 | 03:27 PM
.RJ's Avatar
.RJ
Default Re: Trans swap!!! (gsrboi80)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrboi80 &raquo;</TD></TR><TR><TD CLASS="quote">longer final drive in the type r tranny</TD></TR></TABLE>
They both 4.4
Old Nov 4, 2004 | 03:45 PM
eddiedeader's Avatar
I have a B16 tranny with a KAAZ LSD... it's awesome. The limited slip makes cornering alot better, it feels like you have complete control even while skidding.
Old Nov 4, 2004 | 03:51 PM
rovigian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">no, it definitely comes with stronger something. synchros, i think.</TD></TR></TABLE>
Yes 3rd, 4th and 5th are diff composite syncro
Old Nov 4, 2004 | 04:37 PM
blacknbean's Avatar
Default Re: Trans swap!!! (rovigian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rovigian &raquo;</TD></TR><TR><TD CLASS="quote">
Yes 3rd, 4th and 5th are diff composite syncro</TD></TR></TABLE>
ya i heard the type r tranny is beefed up in certain areas..i would get a type r tranny w/4.7 or 4.9 FD
Old Nov 4, 2004 | 04:43 PM
stevieteg's Avatar
yes, wayyyyyyyyyyy too much gas. This is completely wrong. lsd is ideal for circuit / auto x.
Old Nov 4, 2004 | 05:41 PM
94gsr_vtc's Avatar
Default Re: Trans swap!!! (blacknbean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacknbean &raquo;</TD></TR><TR><TD CLASS="quote">
ya i heard the type r tranny is beefed up in certain areas..i would get a type r tranny w/4.7 or 4.9 FD</TD></TR></TABLE>
this is not true, they are made the same. please state where you got this from, when team-integra.net is back up ill show you the link where michael delaney states this.
Old Nov 4, 2004 | 06:06 PM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr_vtc &raquo;</TD></TR><TR><TD CLASS="quote">
this is not true, they are made the same. please state where you got this from, when team-integra.net is back up ill show you the link where michael delaney states this.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=672557
type r synchros are different. when ff-squad.com is back up i'll find some more info
Old Nov 4, 2004 | 06:36 PM
SiR Inspired ED7's Avatar
how much would the b16 tranny run for?
links would also be great, thanks
Old Nov 4, 2004 | 06:39 PM
94gsr_vtc's Avatar
http://www.team-integra.net/fo...earch
if your on team-integra you know michael delaney knows his ****. i go to T-I when i want to know good, correct info. however, we both think what we want so we'll leave it like that.
edit: i only read the first page but it clearly states theres no advantage with the type r tranny..... it says it a bunch of times....plus how do you know what to believe on the ht link. everyone has different views and i honestly dont listen to that bs unless they list a reputable source for their info...
Old Nov 6, 2004 | 01:59 PM
rovigian's Avatar
Its the syncros that are different. I didn't say anything was beefed up...
Old Nov 6, 2004 | 02:04 PM
SmurfDA's Avatar
From: I live in a town with Boston traffic, mass, united states
the type r was built for the track, hence the lsd, cant go wrong with honda oe quality, id get the type r tranny
tuhboek
Apr 29, 2010 01:52 PM
92hatchboi
May 2, 2007 06:39 PM
chino369
Jul 25, 2006 02:58 PM
LBDM EK97
Mar 20, 2004 07:40 PM
jonoknut
Feb 26, 2003 12:42 PM
