Going d15b2 to d16z6
Old Nov 4, 2004 | 10:26 AM
Schaz's Avatar
Default Going d15b2 to d16z6
I know its all the same being D series so it just bolts in i hope but since its vtec...can anyone help me out with the wiring? ive never done a swap but i am capable of doing one. i just need all the info...sorry about not searching i kno i need the dpfi to mpfi and have a wiring diagram on that but the other wiring i dont know about...unless there isnt any?
1989 Honda CRX Dx D15b2
swap to d16z6
Old Nov 4, 2004 | 10:32 AM
mrspeaker's Avatar
Default Re: Going d15b2 to d16z6 (Schaz)
Get a obd0-obd1 jumper harness and a vtec obd1 ecu..(p28 is the best for d16z6)
And add a couple of wires for vtec..
or stay obd0 buy modifying a 88-91 HF/SI Dizzy to fit on the z6 head..and since you have a DX if u stay obd0 you need to get a different ecu to take advantage of the d16z6...(EX 88-91 civic/crx si ecu or 87-89 integra ecu..etc..)But then u would have to get a switch to activate vtec..
Old Nov 4, 2004 | 11:25 AM
Schaz's Avatar
Default Re: Going d15b2 to d16z6 (Mrspeaker)
okay with the d16z6...i was wondering...does it have power steering? would i have to take that off for my CRX because it dosnet have it? sorry if i sound stupid im just trying to get all bases covered thanks!
Old Nov 4, 2004 | 11:29 AM
mrspeaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schaz &raquo;</TD></TR><TR><TD CLASS="quote">okay with the d16z6...i was wondering...does it have power steering? would i have to take that off for my CRX because it dosnet have it? sorry if i sound stupid im just trying to get all bases covered thanks! </TD></TR></TABLE>
It has a power steering pump ..Just take it off before putting it in your car..
Old Nov 4, 2004 | 11:42 AM
Brownjd's Avatar
see if you can pick up an si tranny somewhere too, unless you
are working on a budget, your dx tranny will work fine too
Old Nov 4, 2004 | 11:45 AM
Schaz's Avatar
Default Re: Going d15b2 to d16z6 (Brownjd)
see this is what the kid says in his sig
FS:
D16Z6 Full Swap, tranny, axles, IM, everything, NO ECU - $400
so all i would need is a ECU its out of a 93 civic so would it be a hydro tranny? and where could i buy an ecu on a TIGHT budget thanks to recently losing my job and my car keeps breaking
Old Nov 4, 2004 | 11:49 AM
EFz6er's Avatar
search the classifieds there are always ecus in there
Old Nov 4, 2004 | 11:51 AM
mrspeaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schaz &raquo;</TD></TR><TR><TD CLASS="quote">see this is what the kid says in his sig
FS:
so all i would need is a ECU its out of a 93 civic so would it be a hydro tranny? and where could i buy an ecu on a TIGHT budget thanks to recently losing my job and my car keeps breaking </TD></TR></TABLE>
any 92-95 civic ex or si ecu (p28) will work Just make sure its a 5spd and not an auto ecu..Check ebay for deals or HT classifieds
All you really need from this guy is the motor/intake manifold..Cant use the tranny cuz its hydro and dont need those axles..
Old Nov 4, 2004 | 11:53 AM
Brownjd's Avatar
you can't use the hydro tranny, and for the ecu, you have to decide if your going to convert to obd-1 or stay non obd. then you can search for a ecu. either a pm6,pg7,or p28 something like that
EDIT: i guess mrspeaker is a faster typer than me
cleanbluef
Jun 1, 2007 01:19 AM
kartracer4
Apr 29, 2005 04:12 PM
Amf_crx
Mar 20, 2004 02:52 PM
chrystyle
Feb 19, 2004 05:29 PM
Blitzed
Jan 10, 2004 11:58 AM
