LS motor swap in a DelSol
Old Nov 4, 2004 | 07:14 AM
93LSTurboSol's Avatar
Default LS motor swap in a DelSol
hey I'm looking to do a Integra LS motor swap into my Del Sol, what can expect to be some difficulties or is it pretty easyto do, and what are some of the things I need to do the swap?
Old Nov 4, 2004 | 07:16 AM
Happyman's Avatar
Default Re: LS motor swap in a DelSol (93LSTurboSol)
Fairly simple. You have a 93 so your car is OBD1 I'd suggest getting an OBD1 swap or atleast an OBD1 Distributor, injectors and ECU to make it easier on yourself. Your going to need b series mounts and the Del Sol VTEC(B16a version) shift linkage.
Old Nov 4, 2004 | 07:49 AM
JeffS's Avatar
check the hybrid forum... that's what it's there for
Actually, search the hybrid forum there's more than enough information.
Old Nov 4, 2004 | 07:53 AM
aberfoyle's Avatar
Default Re: LS motor swap in a DelSol (Happyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Happyman &raquo;</TD></TR><TR><TD CLASS="quote">Fairly simple. You have a 93 so your car is OBD1 I'd suggest getting an OBD1 swap or atleast an OBD1 Distributor, injectors and ECU to make it easier on yourself. Your going to need b series mounts and the Del Sol VTEC(B16a version) shift linkage.</TD></TR></TABLE>
Pretty much what he said. It's a really easy swap have a few buddys come over and help you with it and it should go smooth.
cookie541
Jul 3, 2014 07:53 PM
Ayyxbro
12
Aug 4, 2011 06:50 PM
kdoggparker
Oct 28, 2010 11:51 AM
DuVaL rAcEr
May 5, 2008 08:37 PM
vtec25
Dec 6, 2006 04:23 AM
