re-tourqing head?
Old Nov 4, 2004 | 01:20 AM
dumpeDc2's Avatar
I'm a Jackass
Default re-tourqing head?
thould I re-tq. the head after I rebuild the motor or just use some lock tight and call it a day??
Old Nov 4, 2004 | 05:24 AM
Importracer_001's Avatar
Default Re: re-tourqing head? (dumpeDc2)
I wanna know this too, should you retorque a ARP headbolt?
Old Nov 4, 2004 | 07:15 AM
91civicDXdude's Avatar
dont put loctite on the head bolts, if thats what you're saying. put the head on and if they're reused head bolts, i usually set the torque wrench about 2ft/lb over the recommend torque to account for any stretch in the bolts.
As for ARP head bolts/studs, to my understanding you're supposed to torque them down, then loosen them, and then retorque them. then check them again after a couple hundred miles.
FYI, a local shop told me that ARP head studs/bolts are only good for 2 uses and then you should replace them.. dont know the validity of this statement though.
Old Nov 4, 2004 | 08:07 AM
dumpeDc2's Avatar
I'm a Jackass
Default Re: (91civicDXdude)
so after you take out off you should re Tq. them. im using aebs head studs
Incognito
Sep 18, 2009 12:52 PM
lrayford
Jan 19, 2009 04:33 PM
oranginal
May 2, 2006 11:14 AM
fukaintmuven
Mar 7, 2003 10:57 PM
