Crx stopped running dead in its tracks!!
Old Nov 3, 2004 | 10:17 PM
tRex99's Avatar
Default Crx stopped running dead in its tracks!!
Well i posted on here a few times in the past few days...i said my died at a stop light and never started back up but i have fuel spark the works. Poeple said check timing and i doubt it was the Belt that jumped its tigght..i checked groundtoo!..well i was laying in bed and figured HEY! theres only one damn screw/bolt holding that distributor in place and i messed with it awhile back! what if in some mad-*****rish way its just loose and that Dizzy retard chocked off and died!! im gonna check in the morning but someone tell me it could be!! i hope this is it..
Old Nov 3, 2004 | 10:41 PM
Guest
Posts: n/a
Default Re: Crx stopped running dead in its tracks!! (tRex99)
ummm...it could be
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRex99 &raquo;</TD></TR><TR><TD CLASS="quote">mad-*****rish way</TD></TR></TABLE>
Old Nov 3, 2004 | 10:47 PM
drussell4801's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRex99 &raquo;</TD></TR><TR><TD CLASS="quote"> Well i posted on here a few times in the past few days...i said my died at a stop light and never started back up but i have fuel spark the works. Poeple said check timing and i doubt it was the Belt that jumped its tigght..i checked groundtoo!..well i was laying in bed and figured HEY! theres only one damn screw/bolt holding that distributor in place and i messed with it awhile back! what if in some mad-*****rish way its just loose and that Dizzy retard chocked off and died!! im gonna check in the morning but someone tell me it could be!! i hope this is it..</TD></TR></TABLE>
mount the dizzy right to begin with.
then check your compression. that will verify that your valve timing is correct...
Old Nov 4, 2004 | 08:24 AM
tRex99's Avatar
Default Re: Crx stopped running dead in its tracks!! (drussell4801)
well comes down too i did have it mounted right and it didnt move BUT..its running in my garage as we speak ..only thing i dont like is i dont know how. Im thinking its something to dow ith my dizzy because i bought a new one about 8 months ago why?? cause my last one had some prob and the car would shut off as i was driving and tach was crazy then would die at a light just like this and 20 min later would crank over and start..
I took each plug wire of and stuck a wire in it and jumped form the starter and would see if it had enough spark which they did, now sometimes it would be a weak crank then i would move the wrench some and BAM theres the power crank so im thinking mayeb the ground is jacked to my key ignition switch and isnt giving it the right amount of power..but when the battery is charged it cranks at a normal pace from the key..so im confused im not going to drive it no where till i figure out what it could be...it HAS to be the ignition system i know it...something in that new distributor..if it died then u just waited for a certain amount of time and tried again all the suden it works? bad ground or something...anyone else know?
Old Nov 4, 2004 | 01:02 PM
check <U>ALL</U> grounds.
Old Nov 4, 2004 | 01:09 PM
Sikocivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drussell4801 &raquo;</TD></TR><TR><TD CLASS="quote">check <U>ALL</U> grounds.</TD></TR></TABLE>
There are 3, one is on the valve cover, there is one on the tranny and the third one is on the thermostat housing. Be sure they are all clean and tight.
Old Nov 4, 2004 | 03:27 PM
turbox's Avatar
sounds like the main relay is going bad when mine got hot it did the same thing
took the main relay out tapped it on the ground hooked it back up it started
it did this like a month then it wouldnt start after the tapping i had to replace it
its like 60.00 chris
Old Nov 4, 2004 | 03:48 PM
CRX_Control's Avatar
Default Re: Crx stopped running dead in its tracks!! (turbox)
no..it doesnt sound like main relay.
Old Nov 4, 2004 | 03:53 PM
tRex99's Avatar
Default Re: Crx stopped running dead in its tracks!! (CRX_Control)
well how bout a head gasket leak ..havent checked yet but im thinking its a good possibility. Number one sometimes i have a misfire when i idle i get one off and on posibly from moisture. Then my radiator has been losing water periodicly but doesnt overheat. and today i got it running just messing with the plug wires making them spark without a plug and all the sudden it wanted to start so i let it...went to run up the rpms and it choked..did it slow and it worked...tried again and choke choke pssst and ****** steam came out of my intake tube .... so im going to pull all my plugs and see if they are clean as hella from the steam if so then thats it but if not then i have no idea...crazy *** **** is going on with it..
Old Nov 4, 2004 | 06:37 PM
test your plug wires.
ALLmotorTYPES
24
Jul 7, 2007 08:31 AM
accordinglyevil
Jun 23, 2006 12:32 AM
david
Nov 30, 2005 02:01 PM
civicminded73
29
Jun 29, 2004 07:55 AM
speedracer33
Dec 25, 2003 11:46 AM
