Need Fuse block pin outs for CX civic (92-95)
Old Nov 3, 2004 | 09:15 PM
. o 69 o .'s Avatar
Default Need Fuse block pin outs for CX civic (92-95)
I did a search found lots of completely incorrect info. Im fixing my mess of wiring from my integra dash conversion. I used the integra harness with civic fuse block plugs. All teh signals work, headlights, higebeams work
On the cluster side of things, I know what everything should be
<U>13 pin plug:</U>
1- Immobilizer
2- Immobilizer
3- Not Used
4- Power
5- Maintenance Light
6- Cruise control
7- Ground
8- Coolant Temp
9- Battery Light/Charge Indicator
10- Not used
11- Oil Pressure
12- CEL
13- Tach Signal
<U>16 PIN Plug</U>
1- Fuel Gauge
2- Door Indicator
3- Not used
4- Low Fuel Indicator
5- Not Used (?)
6- Speedometer
7 -Trunk Light
8- Seat Belt Light
9- Power
10- Power
11- Power
12 - Not used
13- Left Turn signal
14- Right turn signal
15- High Beam
16 - E-Brake
So somewhere along the way i screwed up most of the actual gauges. So if anyone has the layouts for the fuse block side, it would be greatly appreciated.
Old Nov 4, 2004 | 09:49 AM
. o 69 o .'s Avatar
Default Re: Need Fuse block pin outs for CX civic (B16B)
bump
Old Nov 11, 2004 | 08:17 AM
. o 69 o .'s Avatar
bump
Brian Virnig
Honda CR-V & Element
Feb 28, 2019 12:50 PM
dbailey
Jan 5, 2006 06:04 PM
FyReo3
Dec 23, 2005 05:50 PM
EGkTiOn_CiViC
Aug 30, 2002 06:03 PM
