can i put a y8 head on a ZC block?
Old Nov 3, 2004 | 01:23 PM
dryhopsux13's Avatar
Default can i put a y8 head on a ZC block?
i just aquired a fully built ZC block. I have an extra y8 head and i was wondering if this sorta mix/match setup will work. i have a 96 civic coupe converted to obd1..if that helps...
Old Nov 3, 2004 | 02:10 PM
93CivicSI's Avatar
Default Re: can i put a y8 head on a ZC block? (dryhopsux)
SEARCH https://honda-tech.com/zerosearch
this subject has been covered 100's of times.....
Old Nov 3, 2004 | 04:01 PM
Default Re: can i put a y8 head on a ZC block? (93CivicSI)
searched...to bad the search option doesnt allow me to use the word zc because it only has two letters...so yea....i couldnt find anything...anyone got a link for me, or sum info?
Old Nov 3, 2004 | 07:05 PM
Old Nov 3, 2004 | 07:06 PM
BauleyCivic's Avatar
Risky Business
on a sohc zc block yes, on a dohc zc block, no
Old Nov 3, 2004 | 08:14 PM
Knightmare69's Avatar
Default Re: can i put a y8 head on a ZC block? (BauleyCivic)
What kind of difference would this make?
Old Nov 4, 2004 | 03:52 AM
Default Re: can i put a y8 head on a ZC block? (Knightmare69)
im not sure wut kind of differance it will make, but i thought id try it out since i have the fully built block in my possesion.
Old Nov 4, 2004 | 04:31 AM
bluemax189's Avatar
supposedly, the z6 head flows a little better and the y8 manifold flows better. Unless you messed up your head and need a replacement, dont worry about changin them
Old Nov 4, 2004 | 01:17 PM
Default Re: can i put a y8 head on a ZC block? (bluemax189)
ZC...not z6......im trying to figure out if i can put a y8 head onto a ZC block.
Old Nov 4, 2004 | 01:24 PM
i have heard that if i put my y8 head on the ZC block it will mess up my timing and my car wont run right at all. ???????????????????????????
Old Nov 4, 2004 | 01:29 PM
jspresso's Avatar
yes it will fit, will it make a hp diff hardly any, if on an eg you will need to change the intake mani since the head is an obd2 and an eg is an obd1
Old Nov 4, 2004 | 01:37 PM
chad's Avatar
Moderator
sure it will work and can be done....send me the head, the block and 10,000 dollars....
Old Nov 4, 2004 | 01:38 PM
chad's Avatar
Moderator
Default Re: can i put a y8 head on a ZC block? (jspresso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jspresso &raquo;</TD></TR><TR><TD CLASS="quote"> if on an eg you will need to change the intake mani since the head is an obd2 and an eg is an obd1</TD></TR></TABLE>
wrong wrong and more wrong!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
UTJoeC33
Feb 28, 2006 06:30 AM
SOHCRipper
Feb 6, 2006 02:52 PM
the jdmchop
Feb 3, 2004 10:12 AM
4gvtec
Oct 1, 2002 04:36 PM
