Engine Rebuild for FI
Old Nov 3, 2004 | 11:51 AM
JDM00SI's Avatar
Default Engine Rebuild for FI
i currently own a 5th gen prelude w/ 120k miles on the engine. i want to turbo this vechile, although people say my engine is too worn out. Well if i get the engine rebuilt including the tranny, will it be good enough to turbo? when i rebuild the engine, is it like the milage on the engine goes back to 0 miles? thanks
Old Nov 3, 2004 | 12:20 PM
JDM00SI's Avatar
Default Re: Engine Rebuild for FI (bigbeasta4)
bump
Old Nov 3, 2004 | 01:24 PM
drdisco69's Avatar
Yes. But you don't want to rebuild it to stock for forced induction. You'll want better rods and pistons.
Old Nov 3, 2004 | 01:58 PM
JDM00SI's Avatar
Default Re: Engine Rebuild for FI (drdisco69)
i always hear of people taking thier engines completely apart and putting it back together...its supposed to make the engine more reliable i guess? Am i missing something? Thanks
Old Nov 3, 2004 | 02:24 PM
ExospeedAMcrx's Avatar
theres 2 ways of rebuilding. 1 is to completey refresh the engine with all new STOCK parts, like it was from the dealer. or You can use upgraded parts that will be stronger and hold up to the abuse you want to put it through.
A stock engine has its limits. but with a Built engine, it has more potential.
Old Nov 3, 2004 | 04:48 PM
JDM00SI's Avatar
Default Re: (exospeedAMcrx)
ohhh.....do people usually take apart thier engines and just put them back together to improve reliablity or something? thanks
Old Nov 3, 2004 | 05:14 PM
PrettyLude's Avatar
upgraded parts, so they can take more abuse
Old Nov 3, 2004 | 05:22 PM
drdisco69's Avatar
Default Re: (bigbeasta4)
I think the concept here is that you don't just take it apart, say "Oooh, neat." and put it back together. You replace worn parts, and upgrade any that will need to be stronger for other upgrades you plan on doing.
Old Nov 3, 2004 | 06:57 PM
GWInquisitor14's Avatar
Default Re: (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">I think the concept here is that you don't just take it apart, say "Oooh, neat." and put it back together. You replace worn parts, and upgrade any that will need to be stronger for other upgrades you plan on doing.</TD></TR></TABLE>
Old Nov 4, 2004 | 07:36 AM
derekcarr's Avatar
If you are building it for boost then you will want to upgrade the bottom end. You will also want machining done to make sure you have a good solid block and head to start with. Then while at the machine shop you want to replace the pistons so that you cylinder to piston clearances are bang on. Then have the machinest balance the pistons and mark them to the cylinder they match. You can also get the machinest to balance the connecting rods, and the crank. Just a few ideas for you, there are alot more things you can do if you have the time and the money to get them done. It all depends on what you are looking for in the end.
Derek
Old Nov 13, 2004 | 01:49 PM
derekcarr's Avatar
Default Re: Engine Rebuild for FI (derekcarr)
And then there is the head work...
Derek
Accordian47
Aug 13, 2018 04:55 PM
Miikeey
Apr 6, 2015 08:07 PM
Adampops
Jan 5, 2002 07:30 PM
