LS turbo project completed(56K warning)
Old Nov 2, 2004 | 06:50 PM
D-tuned's Avatar
Default LS turbo project completed(56K warning)
I'm going to make a long story short. I have a 00 civic SI with a fully built 2.0L GSR motor with an LS crank. We blew the rings on #4 piston racing one night. I decided to take the engine out of my daily driver and put it into a hatch or crx and take it racing on the weekends. I picked up a 93 B18A1 with 90,xxxmiles on it from U wrenk it. I decided to rebuild it to stock using all factory honda part to get the experience of rebuilting my first engine. I replace the water pump, timing belt, bearings, rings, and every gasket I could get my hands on. The head and the block was sent out to abacus to make sure everything was staight and get the block honed, and file fit the rings. I went ahead and painted the engine for fun. My setup: arp head studs, ard rod bolts, garrett T3/T4 57trim 60/63 with stage III wheel, HKS SSQV, AEM C2DI, honda 01 CBR 954 coil sticks(I converted my ignition to distributorless system) 38mm tial wastegate, apexi boost soleniod(EMS controls boost), SFP manifold, AEM fuel rail, B&M fuel pressure regulator, AEM uego single channel wideband O2 sensor, precision 880cc injectors, AEM EMS 1010, 00 SI tranny, clutch masters stage III clutch, type R flywheel, 3" downpipe with 3" race ready, greddy evo 2 catback exhaust, and a custom intercooler. I know some people are going to say the injectors are too big. I dont think so. I'm using a boost comp'ed map on my EMS and I turned the fuel pressure down so my injector duty cycle wouldn't be too small and affect the drivability of the car. I have the car idling at 900rpms and in the process of breaking it in(I'm doing a hard breakin). So far the car sounds and drives great. I have an appointment on thursday to get dyno tuned. I'm going to be doing all the tuning myself. My goal is 300whp. I will post up the dyno on thursday when I'm done and post some more pics of the car.
painted black
the block with the factory pistons. I cleaned the up
the finished engine. red valve cover,black head,red block,black tranny
another shot of the engine
the in the car with the intercooler
I would like to give big thanks to jay and matt at next level performance. Without there help this wouldnt be possible. I'd also like to thank abacus racing for doing all the machine work.
Modified by 2000civicsi at 6:12 AM 11/3/2004
Old Nov 2, 2004 | 07:11 PM
b16boost's Avatar
Default Re: LS turbo project completed(56K warning) (2000civicsi)
Sick
Old Nov 2, 2004 | 07:16 PM
Hawkze_2.3's Avatar
Man, that looks GOOD. Have fun
Old Nov 2, 2004 | 07:40 PM
hitvtecgetloud09's Avatar
Default Re: LS turbo project completed(56K warning) (Hawkze_2.3)
can i have it? plz?
Old Nov 2, 2004 | 07:45 PM
turbo83lude's Avatar
looks great.....i love the look of the LS valve cover
Old Nov 2, 2004 | 07:48 PM
mrbsponge's Avatar
mor einfo on the ignition system, sounds hot, looks good 2
Old Nov 2, 2004 | 08:43 PM
accordfreak's Avatar
Default Re: (mrbsponge)
wow huge intercooler.. what's the dimensions? 24"x12"x3"?
Old Nov 2, 2004 | 09:10 PM
D-tuned's Avatar
Default Re: (accordfreak)
I got it almost two years ago
Old Nov 3, 2004 | 02:07 AM
JoseCuervo's Avatar
Default Re: (2000civicsi)
Hey "D";
This is Jose. Everything looks good brother. Good job on getting it done. Let me know what the HP output is after the dyno. Later.
Old Nov 3, 2004 | 05:29 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: (JoseCuervo)
Stock rebuild?
Old Nov 3, 2004 | 05:36 AM
Turbocivic94's Avatar
Default Re: (boostincoupe)
Looks good so far
I would have put a block guard in for haha's
Old Nov 3, 2004 | 06:48 AM
D-tuned's Avatar
Default Re: (Turbocivic94)
I was going to put a block guard on it but I was adviced not to.
Old Nov 3, 2004 | 08:13 AM
Snail EK's Avatar
Old Nov 3, 2004 | 08:16 AM
GRTechnologies's Avatar
Default Re: LS turbo project completed(56K warning) (Snail EK)
Old Nov 3, 2004 | 08:40 AM
m R g S r's Avatar
Why stock pistons?
Old Nov 3, 2004 | 09:26 PM
D-tuned's Avatar
Default Re: LS turbo project completed(56K warning) (m R g S r)
I used stock pistons because I was on a budget and I already have a engine thats fully built. I just want a realiable daily driver. With the other engine in the car it was just too much of an headache.
Old Nov 5, 2004 | 01:40 PM
Boostfed's Avatar
New User
Cool Dameon! Now you can give me my props for using the shop's dyno and making me stay WAAAAAAAAAAAY past working hours!!!!!!
Modified by Boostfed at 10:29 PM 11/5/2004
Old Nov 5, 2004 | 06:28 PM
Boostfed's Avatar
New User
We are on the dyno, so far 303whp 274ft-lb 20psi straight stock 93 LS motor with a 94 LS intake, SFP turbo mani, T3/T04E 57 trim, AEM tunage! Dameon is happy! Call Street Motorsports for dyno tuning or dyno time (757)965-3494 ask for Terry. http://www.streetmotorsports.com Don't be intimidated by the Mustangs on the website we are expanding to Imports ALA Boostfed! http://www.boostfed.net : Plug : : Plug :
Edit:93 octane also! Thanks st00pid for some LS tuning advice!
Modified by Boostfed at 10:58 PM 11/5/2004
Old Nov 5, 2004 | 06:58 PM
Boostfed's Avatar
New User
Final #s after tuning 310whp 274 ft-lb torque. Dameon is happy with it! See everyone who goes to Imports VS Dumbmestics(just kiddin) WWWIII on Sunday at Maryland Internation Raceway.
Old Nov 5, 2004 | 07:18 PM
turbo*s2k's Avatar
Default Re: (Boostfed)
motor looks good! Congrats
Old Nov 5, 2004 | 07:24 PM
StolenTeg's Avatar
Default Re: (TurboChrgd_Civic)
Motor look extremely clean. but you should have dissed you another 700 and get forged piston and rods...
Old Nov 5, 2004 | 08:36 PM
D-tuned's Avatar
Default Re: (StolenTeg)
I want to give terry at street motorsports made props for hooking me up on the dyno. I tuned the car myself(my first one). final numbers are 310.9whp 274.3wtq @20psi . I will post my dyno sheet as soon as I can get my hands on a scanner. I'm going to import vs domestic this weekend to see what she'll do on the track. I'll post my times when I get that too. If you guys need any parts, dyno time or dyno tuning give terry and the guys at street motorsports a call. I'm sure you'll be leaving there happy. Dont forget to check http://www.streetmotorsports.com and http://www.boosfed.net ask for terry aka boostfed
Modified by 2000civicsi at 4:11 PM 11/6/2004
Old Nov 5, 2004 | 09:12 PM
KingOfQB's Avatar
stock ls on 20 psi???????
Old Nov 6, 2004 | 01:38 AM
D-tuned's Avatar
Default Re: (KingOfQB)
fuch yeah 20psi on a stock block
Old Nov 6, 2004 | 01:39 AM
D-tuned's Avatar
As soon as I can get my dyno sheet scanned it will be up here.
