Si tranny with a HF final drive?
Old Nov 2, 2004 | 05:09 PM
mr_valentino20032000's Avatar
Default Si tranny with a HF final drive?
like that says^^^....
Does anyone have this done? I'd love to have the acceleration of an Si tranny through 1st,2nd,3rd, and 4th, but have the highway cruising of the HF (based on http://crx.honda-perf.org/math/index.html )for better gas milage. So is this do-able and easy? I honestly have no realistic clue about all the tranny talk, mostly because i'm still learning all the engine stuff.
I searched and didn't find much but that site. So any input would be nice
Old Nov 2, 2004 | 05:12 PM
CRX_1.8T's Avatar
Default Re: Si tranny with a HF final drive? (mr_valentino20032000)
this is a real good question, i've wondered this too.
Old Nov 2, 2004 | 05:14 PM
Default Re: Si tranny with a HF final drive? (CRX_1.8T)
i'd love to get better gas milage than i did before if at all possible, and if you are going for quickness you wouldn't even shift to 5th, so it'd be a just highway gear......just like i want
Old Nov 2, 2004 | 05:16 PM
crxgator's Avatar
so get a dx tranny...
Old Nov 2, 2004 | 05:17 PM
Default Re: Si tranny with a HF final drive? (crxgator)
i want the "slap you back in the seat" feeling you get from the Si tranny, with only 100 HP under the hood
Old Nov 2, 2004 | 05:22 PM
91civicDXdude's Avatar
the final gear is what gives you the acceleration. you want to change out the 5th gear, not the final gear. As long as the shafts are the same size, you can swap them out. I've never taken apart an HF tranny, but i know the DX and Si have the same shafs.. i heard the HF has smaller bearings which would mean smaller shafts so the gear wouldn't work.
If you have an HF tranny, take it apart and take the 5th gear out and see if it fits in your tranny
Old Nov 2, 2004 | 05:24 PM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_valentino20032000 &raquo;</TD></TR><TR><TD CLASS="quote">i want the "slap you back in the seat" feeling you get from the Si tranny, with only 100 HP under the hood </TD></TR></TABLE>
si and dx have the same gear ratios just different final drives...you need to swap just the 5th gear than for gas mileage...
Old Nov 2, 2004 | 05:37 PM
skittyscott's Avatar
my dx gets 37mpg and my si gets 33mpg. i dont think its even worth the swap.. but if someone can come up with more info on the hf 5th lemme know. im very interested too
scott
Old Nov 2, 2004 | 05:38 PM
Bserieskllr's Avatar
why not zc 1-4, hf 5th and si final.
Old Nov 2, 2004 | 05:52 PM
bspeed's Avatar
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">the final gear is what gives you the acceleration. you want to change out the 5th gear, not the final gear. As long as the shafts are the same size, you can swap them out. I've never taken apart an HF tranny, but i know the DX and Si have the same shafs.. i heard the HF has smaller bearings which would mean smaller shafts so the gear wouldn't work.
um, the shafts are all the same I.D. you can even put cable gears into a hydro box. their height is the only difference. you just have to shim the gears to get the same install height.
Old Nov 2, 2004 | 07:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">
si and dx have the same gear ratios just different final drives...you need to swap just the 5th gear than for gas mileage...</TD></TR></TABLE>....so it will fit&gt;? has anyone done it?
Old Nov 2, 2004 | 07:34 PM
crxgator's Avatar
Default Re: (mr_valentino20032000)
yes it will fit...
Old Nov 2, 2004 | 10:34 PM
davens's Avatar
1. "Final Drive" is not the same thing as 5th.
2. You can put a HF 5th in an otherwise stock si tranny. This make your 5th gear cruise right about 400 rpms lower then before.
3. Is it worth it? Debateable. You'd have to spend a lonnnggg time in 5th to see a MPG benefit. It is a noticeably quieter at 80 mph though.
Old Nov 3, 2004 | 04:37 AM
Default Re: (davens)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens &raquo;</TD></TR><TR><TD CLASS="quote">1. "Final Drive" is not the same thing as 5th.
3. Is it worth it? Debateable. You'd have to spend a lonnnggg time in 5th to see a MPG benefit. It is a noticeably quieter at 80 mph though.</TD></TR></TABLE>
ok so you can put the 5th gear onto the Si tranny, but the final drive is a no. Ok and the reason was more like a cruisin RPMs type thing. As i remember it was like 4500 to cruise at 75, and the "final drive" on the HF was at 3200 so yeah it'd like to be able to hear better too
Old Nov 3, 2004 | 04:41 AM
92integra_gs's Avatar
Old Nov 3, 2004 | 03:00 PM
31flavorscivic's Avatar
Default Re: (92integra_gs)
if you switched out the final drive you'd prolly lose or mess up whatever acceleration you liked about that Si tranny. 5th is the way to go.
Old Nov 3, 2004 | 03:04 PM
Default Re: (31flavorscivic)
ok so forget the final drive, but yes to the HF 5th gear in a Si tranny. Will there be a diffrence? and what does the final drive do????
Old Nov 3, 2004 | 03:09 PM
Tyson's Avatar
the final drive is the base gearing between the diff (axles) and the input shaft (engine). each gear (1-5) multiplies that final drive ratio for an overall gearing ratio.
for example, on a 21 speed bicycle, you have 3 final drives to choose from, and 7 gears to select. for a car, it would be as if you only have one big gear at the pedal and 5 gears on the rear wheel.
Modified by Tyson at 4:23 PM 11/3/2004
Old Nov 3, 2004 | 03:23 PM
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">the final drive is the base gearing between the diff (axles) and the input shaft (engine). each gear (1-5) multiplies that final drive ratio for an overall gearing ratio.
for example, on a 21 speed, you have 3 final drives to choose from, and 7 gears to select. for a car, it would be as if you only have one big gear at the pedal and 5 gears on the rear wheel. </TD></TR></TABLE>
Thank you for that explanation. I'm so happy that i now understand it. SO i should be able to keep the Si final drive and the HF 5th gear will work right???
Old Nov 3, 2004 | 03:42 PM
Jim Truett's Avatar
Thank you for that explanation. I'm so happy that i now understand it. SO i should be able to keep the Si final drive and the HF 5th gear will work right???</TD></TR></TABLE>
Yes. You need the mainshaft 5th and countershaft 5th from the HF for it to work.
Old Nov 3, 2004 | 03:44 PM
Default Re: (Jim Truett)
does anyone happen to have a pic of a disassembled tranny? I'd like to see what parts i'd need
nihad
14
Jan 18, 2007 03:24 PM
md88hfcrx
24
Nov 24, 2005 11:07 AM
ceLtic
Apr 6, 2004 05:52 PM
alky350
May 14, 2003 06:17 AM
Nossy
Apr 24, 2002 02:49 AM
