Tach help needle bouncing
Old Nov 2, 2004 | 04:33 PM
Another B16's Avatar
New User
Default Tach help needle bouncing
The car runs fine but when it gets to about 5000 rpm it bounces all the way from 0 to 8000. Any suggestions on why. It works fine and is steady below 5000.
Thanks
Old Nov 2, 2004 | 04:39 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Tach help needle bouncing (Another B16)
That can be a sign of ignitor failure..
Pull off the distributor cap and check the connections..
Old Nov 2, 2004 | 04:50 PM
keithg's Avatar
In my experience it means that your distributor is failing or will fail soon, you might want to get a back up distributor ASAP.
Old Nov 2, 2004 | 04:53 PM
4DRmafia's Avatar
i dont mean to jack the thread but this is abt my mph is keep bouncing from 0 to 35 mph then after 40mph it goes normal ....why does this do this ?
Old Nov 2, 2004 | 05:05 PM
drdisco69's Avatar
Default Re: (SkipMic2006)
The tach bouncing is the ignitor on the way out. Keep a spare in the glove box, and get ready for The Big Stop.
The speedo bouncing is usually the vehicle speed sensor taking a ****.
Old Nov 2, 2004 | 05:20 PM
88DXCRX's Avatar
Default Re: (drdisco69)
I always carry a spare already mounted to the heatsink
because mine has gone out twice now..once bitten twice shy..
The second time I replaced it on the side of the road..
If it says "OKI" on it,it is a piece of crap..
Skip Mic:i dont mean to jack the thread but this is abt my mph is keep bouncing from 0 to 35 mph then after 40mph it goes normal ....why does this do this ?
One thing that will cause this is if the speedometer cable needs to be lubed..
Without grease it will hang and bind or "whip" and cause the needle to flucutate..
Old Nov 2, 2004 | 05:24 PM
4DRmafia's Avatar
umm i see
Old Nov 2, 2004 | 05:27 PM
drdisco69's Avatar
Oops, yeah. I didn't see the year of your car in your sig. No speed sensor in the trans... I suk.
Old Nov 2, 2004 | 05:36 PM
b18cEF9's Avatar
check your grounds, my rpm did the same and i checked my ground and the grounds by the thermo wasnt tight, fixed my problem
Old Nov 2, 2004 | 05:59 PM
sit220's Avatar
Default Re: (b18cEF9)
check the conections inside ur distributor (blue wire)
Old Nov 21, 2004 | 09:57 AM
tur3oDC4's Avatar
Default Re: (sit220)
Where can i get a 88 crx si ignitor?
Old Nov 21, 2004 | 01:04 PM
tur3oDC4's Avatar
Default Re: (B18CRXjake)
Hey, thanks for the info guys, i had a bouncing tach since I bought the car. I fuked around with the dizzy, cleaned some **** ... and now it works perfect. thanks again.
MtnCRX
Jan 11, 2006 10:51 AM
De_tour
Dec 15, 2005 06:59 PM
jdmcraze
Jun 15, 2004 09:37 AM
Nextelbuddy
18
Jun 14, 2003 06:12 AM
B20zvtecek
Jun 24, 2002 06:47 AM
