tow points for jack stands?
Old Dec 22, 2001 | 03:15 AM
mr tl's Avatar
Default tow points for jack stands?
ive seen it done before, but just wanted to make sure
can i put jack stands under the front tow points (hooks) to support the front of the car? the jacks i have dont fit under the factory jack points on the sides
my next idea was to cut the jacks a bit shorter...but i wanted to avoid it
Old Dec 22, 2001 | 04:33 AM
Roach2k's Avatar
New User
Default Re: tow points for jack stands? (mr tl)
are the factory jack points on the sides designed for the scissor tire jack? if so, then i wouldn't suggest putting the stands on them because at least on domestics, it's just flimsy sheet metal and isn't designed to have weight held up on those points
Old Dec 22, 2001 | 06:49 AM
NighthawkR184's Avatar
I usually put my jack stands under the sway arm bushings in the front and on the back I put them on the sub frame. I usually use a sisor jack in the front to the car up high enough to get a floor jack under the tranny then jack it high enough to get the stands under the sway arm bushings. in the back I take the lower tie bar off and put the jack on the cross member and raise it up. I dont like putting the jack under my tranny but I have not found a better way. I haven't had any problems from it. I wouldn't recomend that if you have an automatic.
Old Dec 22, 2001 | 07:26 AM
rainforest's Avatar
Default Re: tow points for jack stands? (flamencoR184)
i go for the pinch frame. its ok to do the lowerr control arms where it connects to the subframe.
Old Dec 22, 2001 | 08:45 PM
Mista Bone's Avatar
D Tranny Guru
DO NOT USE THE TOW HOOKS as jack/support points.
They look beefy, but the can bend.
Buddys car was using jackstands there.
Needed
1 radiator
1 condensor
1 lower core support
when the tow hooks folded over and car fell off the stands.
93supercoupe
Feb 13, 2012 06:22 PM
Atomic1
Jun 22, 2010 07:45 PM
ZipTieGUy
Suspension & Brakes
Feb 3, 2006 08:18 PM
VTEConly
Aug 14, 2004 08:13 AM
Loveless
Jun 29, 2003 06:05 PM
