I need help selecting a set of cams for my GSR
The engine specifications are:
-B18c1 block border out to 25m over with cp pistons compression 11.1 with eagle rods.
-ported and polish b18 head with the whole valve train from Ferrera, flow bench test in the head came up to 327 (the valves in the head are high compression valves so I think the compresion might be arround 11.3 or 11.4)
- Dc heathers 4 to 1. Custom exhaust 2.5 with a skun2 catback.
- skunk2 manifold and cam gears (manifold was also flow bench with the head and heathers).
- BBK 70m throttle body.
- walbro 255 fuel pump and aeromotive fuel pressure regulator with an AEM fuel rail, also RC 310 injectors
** a 80 shot of nos will be added to the car on a direct port system**.
My question is I was trying to get some skunk2's stage 2 but I don’t know if that is a good idea for the overlap in the valves, any ideas or suggestions?
PS any ideas are welcome thank you.
Modified by robGSR at 3:02 PM 11/2/2004
You should not have any clearance problems with the s2 stg 2 cams. Have you ever surfaced the head or block? If so how much?
spags930
Apr 5, 2010 12:20 PM
