ABS 94ex /94gsr brake options
Old Nov 2, 2004 | 11:11 AM
ish474's Avatar
Default ABS 94ex /94gsr brake options
I have a 94 ej1 with 4wheel disc 4wheel abs. (These are the exact same size as gsr front and rear found out the hard way after shelling out the dough for the swap)
and I have had problems with the abs not working or working too much and wanted to know if anyone has had simalar problems an if so what advice you had. The whole suspension was swapped including springs and now has an ls motor. I have been running this setup for 3 0r 4 years and have always had problems with brakes. I now have sbs rotors and pads all the way around and while it stops a lot better it seems to lock the rears now instead of activating the abs which used to be hyper active. any thoughts. I drive in the mountains a lot and can' live without the slotted rottors they allways used to fade really bad. With the new rotors I havent been able to make them quit yet.
Old Nov 3, 2004 | 02:05 PM
ish474's Avatar
Default Re: ABS 94ex /94gsr brake options (ish474)
bump
integrabois1991
Texas -OK -LA (Sales)
May 13, 2010 12:24 AM
climb_on
May 9, 2008 09:02 PM
RiCE On IcE 2
May 10, 2004 02:26 PM
Teggyb18b
Dec 18, 2001 02:49 PM
ajchen
18
Oct 3, 2001 10:42 PM
