Found oil where it doesn't belong
Old Dec 21, 2001 | 08:54 PM
shingles's Avatar
Default Found oil where it doesn't belong
I found oil in the spark plug opening. The car doesn't smoke, and there's no oil in the radiator or in the coolant over flow tank. I am thinking that the gaskets around the opening is bad? Does this sound reasonable?
Also, oil in there, a fair amount... could it hurt performance?
thanks,
-Shing
Old Dec 22, 2001 | 05:43 AM
chi1874436's Avatar
Default Re: Found oil where it doesn't belong (shingles)
If you found oil in the area where the spark plugs are located and your car does not smoke at all, then it must be the little small oil seal gaskets under the valve cover. Also, run a compression test to ensure their is no other worries.
Old Dec 22, 2001 | 07:28 AM
rainforest's Avatar
Default Re: Found oil where it doesn't belong (chi1874436)
yes btween the head and the valve cover there are gaskets so that doesent happen. All you have to do is take off the valve cover and put new gaskets in or gasket.
CRXREFIC
Dec 17, 2010 01:45 AM
jakop92
Nov 15, 2009 11:33 AM
keilux
53
Aug 17, 2009 05:43 PM
cwhat
Dec 3, 2006 10:53 AM
sdinteg
Mar 27, 2005 09:22 PM
