can i paint my rims?
Old Nov 1, 2004 | 09:49 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default can i paint my rims?
can i paint my rims with genneral porpose less than 200 F degree spray paint? what will the heat from the brakes do?
Old Nov 1, 2004 | 10:08 PM
eda6's Avatar
Default Re: can i paint my rims? (DieMaster)
I doubt your rims will ever get to 200 deg. Use ceramic engine enamel. It's good up to 500 deg.
Old Nov 1, 2004 | 10:10 PM
X-Man006's Avatar
Default Re: can i paint my rims? (eda6 hatch)
I painted my rims with regular spray paint and it worked good.
Old Nov 1, 2004 | 10:25 PM
BOSS-REX's Avatar
A good sand blast, and some engine enamel should do the job.
If you got some extra money powder coat looks very custom.
Old Nov 1, 2004 | 10:43 PM
DieMaster's Avatar
Default Re: can i paint my rims? (BOSS-REX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOSS-REX &raquo;</TD></TR><TR><TD CLASS="quote">If you got some extra money powder coat looks very custom.</TD></TR></TABLE>
LOL i'm cheap and saving for other things. all i want is the rims to be black intead of a unpainted / rust color. also will one can be enough for all 4 rims and then some?
Old Nov 1, 2004 | 10:47 PM
doublethink's Avatar
clean them really well with degreaser (cheap) then soap and water.
let them fully dry, tape off the tires, and use either engine enamal, or straight up krylon even rustolium if you want.
thats the cheap route done right. but higher temp paint will hold up better, a clear coat would hurt for scratches. also just having a body shop or rim place do it is a good idea too, but you said you have no loot so....
good luck.
Old Nov 2, 2004 | 07:03 PM
BOSS-REX's Avatar
2 cans of black will do
O.K. money is always an issue, So you can clean them cheep by borrowing some detergent from Mom a freebie, a scotch bright from the kitchen sink that the sponge that Mom uses to clean dishes with or SOS pads, and hot water in a bucket. 2 cans of paint will get the job done on the outside of the 4 wheels probably some to spare but paint the outer rims first just in case you run low on pant.
Good luck man.
Old Nov 2, 2004 | 07:25 PM
SpecialEdxl's Avatar
i was thinking about doing the same thing cus this kid wanted to sell me some 15's that arent that bad, i may get them with in the next 2 weeks and see how it turns out.
Old Nov 2, 2004 | 08:13 PM
sd.coupe's Avatar
POWERD COAT
Old Nov 3, 2004 | 05:12 AM
92integra_gs's Avatar
1 and a half can of paint would take care of the set... you just need to clean the rims out good... and put some bulldog adhesive spray... it will make your paint stick better and last longer...HTH
Nicram
Jul 14, 2005 01:20 PM
DreamAtlantis
Jun 2, 2005 08:49 AM
thisbwill
Jun 19, 2003 05:31 PM
Blue-Civic-Hybrid
Jan 3, 2002 07:07 AM
