compression test
Old Nov 1, 2004 | 07:52 PM
TRUTHUGSOULJAH's Avatar
Default compression test
I have a b16 motor,, is runs fine, but when i pull the spark plug wires off cyl # 1 nothing happens then 2 nothing happens then 3 they there is a differance then 4 nothing happens,, only 1 plug makes a differance,, any info on that will help thanks. weird.
Modified by TRUTHUGSOULJAH at 9:11 PM 11/1/2004
Old Nov 1, 2004 | 07:58 PM
drdisco69's Avatar
Default Re: compression test (TRUTHUGSOULJAH)
What does that have to do with a compression test?
If the car runs fine, what is the problem? Don't go looking for trouble, it will find you.
Old Nov 1, 2004 | 08:01 PM
Default Re: compression test (drdisco69)
i thought if u pull any plug the car suppose to drop and idle low,, thats all.
Old Nov 1, 2004 | 08:05 PM
drdisco69's Avatar
Normally, yes. But if it really is running ok, I wouldn't question it. Something about a gift horse in the mouth.
Why were you pulling the plug wires? Did you have a reason to suspect something was wrong?
Old Nov 1, 2004 | 08:14 PM
i just did a swap a b16 in a 93 hatch, just fine tuning it
Old Nov 1, 2004 | 08:42 PM
badoosi's Avatar
Have you tried tuning the distributor and fuel pressure? Whenever I take my car into to get tuned, that's what my mechanic does and it feels so much faster.
juanintec
Sep 24, 2007 09:58 PM
iHOPEyouCHOKE
Apr 21, 2006 06:40 AM
bmiller17
Apr 2, 2006 01:57 PM
ScaleExtric
Jun 17, 2003 03:09 PM
yellow blur
Aug 25, 2001 07:55 PM
