help !!! gas leaking when i reinstalled stock fuel pressure regulator!!
any ideas why??? no leak in the hose. is the hose supposed to go half way when connecting to the regulator?? this is not the vacuum line. im talking about the fuel hose..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by People_Mover »</TD></TR><TR><TD CLASS="quote">tephlon tape yo</TD></TR></TABLE>
that wont solve the issue dumb ***
listen .. when you removed the fuel pressure regulator... I am assuming you failed to relize there was a small plastic or rubber o-ring that seats in a groove on the bottom of the regulator, then the regulator goes onto the rail... so basically the ring is between the rail and the regulator...
take the regulator back off ... i bet you $1 thats what you lost or forgot... if you lost it you will most likely have to take your regulator to HOME DEPOT or LOWES and try to find a rubber washer that fits.
Modified by mikestypeRR at 5:46 PM 11/1/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danny98r »</TD></TR><TR><TD CLASS="quote">i guess thats prolly it cuz there was no o ring in the aem </TD></TR></TABLE>
yeah if it is spraying out from between your rail and regulator thats definatly it.
i found the o ring thanks guys. the oem o- ring can be used with the aem fpr too right. parts r so small ..
