help !!! gas leaking when i reinstalled stock fuel pressure regulator!!
Old 11-01-2004, 04:12 PM
danny98r's Avatar
Default help !!! gas leaking when i reinstalled stock fuel pressure regulator!!
any ideas why??? no leak in the hose. is the hose supposed to go half way when connecting to the regulator?? this is not the vacuum line. im talking about the fuel hose..
Old 11-01-2004, 04:13 PM
People_Mover's Avatar
Location: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: help !!! gas leaking when i reinstalled stock fuel pressure regulator!! (danny98r)
tephlon tape yo
Old 11-01-2004, 04:23 PM
mikestypeRR's Avatar
Default Re: help !!! gas leaking when i reinstalled stock fuel pressure regulator!! (People_Mover)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by People_Mover &raquo;</TD></TR><TR><TD CLASS="quote">tephlon tape yo</TD></TR></TABLE>
that wont solve the issue dumb ***
listen .. when you removed the fuel pressure regulator... I am assuming you failed to relize there was a small plastic or rubber o-ring that seats in a groove on the bottom of the regulator, then the regulator goes onto the rail... so basically the ring is between the rail and the regulator...
take the regulator back off ... i bet you $1 thats what you lost or forgot... if you lost it you will most likely have to take your regulator to HOME DEPOT or LOWES and try to find a rubber washer that fits.
Modified by mikestypeRR at 5:46 PM 11/1/2004
Old 11-01-2004, 04:26 PM
danny98r's Avatar
Default Re: help !!! gas leaking when i reinstalled stock fuel pressure regulator!! (mikestypeRR)
i guess thats prolly it cuz there was no o ring in the aem
Old 11-01-2004, 04:31 PM
hYpE-R-29's Avatar
go to kragen or autozone, they have o-rings
Old 11-01-2004, 04:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danny98r &raquo;</TD></TR><TR><TD CLASS="quote">i guess thats prolly it cuz there was no o ring in the aem </TD></TR></TABLE>
yeah if it is spraying out from between your rail and regulator thats definatly it.
Old 11-01-2004, 05:02 PM
Spoon Spec EK's Avatar
Get one from Acura if you can't find one from Home Depot. It is the same size as stock.
Old 11-01-2004, 06:35 PM
danny98r's Avatar
Default Re: help !!! gas leaking when i reinstalled stock fuel pressure regulator!! (Spoon Spec EK)
i found the o ring thanks guys. the oem o- ring can be used with the aem fpr too right. parts r so small ..
turboef90
08-11-2013 12:28 PM
mok
09-12-2006 03:18 AM
racekar
10-30-2004 07:17 AM
Muckman
12-06-2003 01:40 PM
technine
07-03-2002 03:51 PM
Quick Reply: help !!! gas leaking when i reinstalled stock fuel pressure regulator!!
