throwin a code 9...won't rev past 3500
Old Nov 1, 2004 | 03:41 PM
si_hatch's Avatar
Default throwin a code 9...won't rev past 3500
just as title states...my d16z6 motor is throwin a code 9 (cylinder sensor) and it won't rev past 3500, and also my number one cylinder injector is not firing. It's also throwin an injector code but i was thinkin that this was becuase of the code 9?? I just recently replaced my distributor with a rebuilt one because that one had a bad TDC sensor. Car ran fine right after i installed the new distributor but now it's just being gay. Should i just go buy an OEM distributor? thanks in advance
Old Nov 1, 2004 | 07:51 PM
si_hatch's Avatar
Default Re: throwin a code 9...won't rev past 3500 (si_hatch)
bump
Old Nov 1, 2004 | 08:44 PM
badoosi's Avatar
You can't just slap a distributor back on. It needs to be tuned.
Old Nov 2, 2004 | 07:41 AM
egdriver057's Avatar
I HAD THE SAME PROBLEM W/ MY '94 EG COUPE EX. I WAS MESSING W/ THE
TIMING COVER AND FOR SOME REASON I WAS ABLE TO PULL THE CONNECTOR
TO #1 CYLINDER INJECTOR. I DID NOT KNOW ABOUT THIS UNTIL I WAS IN THE
CAR TRYING TO DRIVE WHEN I NOTICE IT ONLY REV TO 3500. THE CHECK ENGINE LIGHT CAME ON BUT I NEVER CHECK TO SEE WHAT CODE IT WAS. WENT TO CHK UNDER THE HOOD AND FOUND #1 INJECTOR CONNECTOR WAS
UNPLUG. CONNECTED BACK IN PLACE AND THE CHK ENG LIGHT DISAPPEAR AFTER YOU DO A KEY CYCLE(TURN IT ON THEN OFF). PLUS IF YOU THINK ABOUT IT, ITS THE ONLY SENSOR(KIND OF CRUDE) THERE IS ON THE #1 CYLINDER.
Old Nov 2, 2004 | 10:52 AM
si_hatch's Avatar
Default Re: throwin a code 9...won't rev past 3500 (egdriver057)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egdriver057 &raquo;</TD></TR><TR><TD CLASS="quote">I HAD THE SAME PROBLEM W/ MY '94 EG COUPE EX. I WAS MESSING W/ THE
UNPLUG. CONNECTED BACK IN PLACE AND THE CHK ENG LIGHT DISAPPEAR AFTER YOU DO A KEY CYCLE(TURN IT ON THEN OFF). PLUS IF YOU THINK ABOUT IT, ITS THE ONLY SENSOR(KIND OF CRUDE) THERE IS ON THE #1 CYLINDER.</TD></TR></TABLE>
well today the injector code went away and now it revs past 3500, but the code 9 is still there....so i guess its not the code 9 that was doin this. I must have a bad connection somewhere with my injector then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by badoosi &raquo;</TD></TR><TR><TD CLASS="quote">You can't just slap a distributor back on. It needs to be tuned.</TD></TR></TABLE>
Tuned? what do you mean
kirbyman
Oct 20, 2024 07:35 PM
SkIp_Civic_Ek6
Nov 27, 2019 10:08 AM
jedb18
May 31, 2008 12:32 PM
Airbag Club
11
Mar 10, 2005 03:05 PM
djtony5
Feb 4, 2003 06:10 PM
