Mini-Me Tech Question
Guys, I have a question up in the Tech section. Please check it out, I need some good advice on a couple of things. Thanks in advance.
Here's the link: https://honda-tech.com/zerothread?id=1042022
Stock throttle cable will work, but you will need to do something trick for a bracket.
Most people (including myself) flip the Y8 brack over (so it's upside down) and then only use one of the screws to hold it on (or drill another hole to secure it with 2).
I'm not sure if the EK cable will work with our pedals, but that would be the best solution.
You can use either map - your stock or the one on the TB.
You may also use any of the B-series throttle bodies if you would like a little larger bore for a little quicker response.
I used my stock fuel line from filter to rail.
You can use either- stock or Y8. I just didn't feel like removing my stock one since I didn't have any copper crush washers handy.
I'll be swapping lines when I go put on a new fuel filter.
4drEF...thanks for the info. When you say stock throttle cable, do you mean a stock crx si cable, or the stock dx dpfi throttle cable that;s in my crx dx? The dx cable loops out over the valve cover and back to the throttle rotor. It looks too long to use. Please advise. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF »</TD></TR><TR><TD CLASS="quote">Stock throttle cable will work, but you will need to do something trick for a bracket.
Most people (including myself) flip the Y8 brack over (so it's upside down) and then only use one of the screws to hold it on (or drill another hole to secure it with 2).I used my stock fuel line from filter to rail.
You can use either- stock or Y8. </TD></TR></TABLE>
on the throttle bracket, that's how I have mine set right now (1 screw). It's been that way for 2 years and I have had no problems. My future plan for it is to cut and weld it so I am using both screws.
You'll need the SI throttle cable, I think that the DX/STD one will be way too long to loop around effectively (though I could be wrong and if I had a DX/STD, I'd probably make it work).
I used a STD/DX fuel line on mine, my SI line seemed to have too much twist for me to bolt it on and be comfortable with it not rupturing.
on the throttle bracket, that's how I have mine set right now (1 screw). It's been that way for 2 years and I have had no problems. My future plan for it is to cut and weld it so I am using both screws. You'll need the SI throttle cable, I think that the DX/STD one will be way too long to loop around effectively (though I could be wrong and if I had a DX/STD, I'd probably make it work).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH »</TD></TR><TR><TD CLASS="quote">Replied.</TD></TR></TABLE>
Thanks for the idea.
eg6sy
Jul 11, 2012 10:53 PM
ventturei27
Feb 1, 2010 07:45 PM
fastcrxsi90
Mar 20, 2003 01:10 PM
