NO CAT ON MY 99 GSR NEED 411
Old Dec 21, 2001 | 01:56 PM
KAMIKAZE GSR's Avatar
Default NO CAT ON MY 99 GSR NEED 411
aight folks this is what i did to my car. i took out the cat converter. i knew that check engine light will go on. i heard if u get the 94-95obd1 p72 ecu the engine lite will turn off... is that true? one more thing, with my 99 gsr harness, will it plug derectly str8 to the 94ecu? o yeah do u lose power with the check engine light on ?
*edit* i just added some punctuation so other people wont make this thread into an english class
-tom(ek9t)
Old Dec 21, 2001 | 02:22 PM
Isaac's Avatar
New User
Default Re: NO CAT ON MY 99 GSR NEED 411 (Team SQR GSR)
First, [EDITED-Chris]
Secondly, I think you are a ***.
Third, if you take out the cat, regardless or not what ECU you have you'll get a check engine light. You might as well just take off the entire exhaust since you'll have a missing link anyways. You either need to buy a high flow cat, such as CarSound which is recommend anyways so we don't kill ourselves, or else a test pipe. I know you are new here, but before you post uneducated questions please use this: (Notice the colon?) https://honda-tech.com/zerosearch
Old Dec 21, 2001 | 05:16 PM
gsr98vtec's Avatar
Default Re: NO CAT ON MY 99 GSR NEED 411 (98 GS-R)
you need an obd 2 to obd 1 converter harness for the ecu to work correctly
also, you must remove the other 02 sensor that used to go into the cat
no check engine light will come on then
Old Dec 24, 2001 | 07:05 AM
JumbosGS-R's Avatar
New User
Default Re: NO CAT ON MY 99 GSR NEED 411 (gsr98vtec)
Only thing I can say to this is....Don't get caught!!! Cops every once in a blue moon have a checkpoint for smog. They check your car you are one dead man!!! bad idea...go w/ a high flow
Old Dec 24, 2001 | 07:09 AM
BoM's Avatar
BoM
Default Re: NO CAT ON MY 99 GSR NEED 411 (JumbosGS-R)
here in NJ, its $3000 and and possible impound
Old Dec 24, 2001 | 07:14 AM
Comtechgsr2000s's Avatar
New User
Default Re: NO CAT ON MY 99 GSR NEED 411 (BoM)
Get a high flow cat like Random or carsound. You won't have to change your ECU either.
[Modified by Mugenblkgsr2000, 4:15 PM 12/24/2001]
Old Dec 24, 2001 | 07:52 AM
speedymon's Avatar
Default Re: NO CAT ON MY 99 GSR NEED 411 (Mugenblkgsr2000)
Man Cali sucks when it comes to cops. Well at least you know how black people feel
Old Dec 24, 2001 | 08:35 AM
Chris's Avatar
Default Re: NO CAT ON MY 99 GSR NEED 411 (speedymon)
1. Get a High Flow CAT.
2. Stop the flames.
dmckrazy45
Jul 16, 2005 07:14 PM
brisk
Apr 7, 2004 01:56 PM
Scott_Taylor
Dec 30, 2003 04:18 AM
Nelo_VTI 1.5 JDM
Dec 4, 2002 02:22 PM
GSRacer1
Nov 15, 2002 12:38 PM
