new to turbo chips and fmu??
Old Oct 31, 2004 | 10:16 PM
miketurbohonda's Avatar
Default new to turbo chips and fmu??
hey i got my civic thats turbocharged
i also have a link managment system that no one knows how to insta;ll properly or tune so......
i am looking at buying this turbo chip off ebay :
http://cgi.ebay.com/ebaymotors...33597
and a fmu off ebay aswell
and is this all i need to get my civic boosting pretty good?
no bigger injectors etc....
i have a afc if that would be nesacary?
if im right all i need is:
chip installed
fmu installed
is that right?
your help would be very much appreciated
thanks heaps people
mike
setup
1988 ef3 civic
1600cc ZC Dohc motor
Vf10 ihi turbo
fmic
2" to 2 1/2" cooler piping
2.5"exhaust straight through
Old Nov 1, 2004 | 01:35 AM
PissedoffGS-R's Avatar
Default Re: new to turbo chips and fmu?? (miketurbohonda)
chances are the chip will make you run lean and boom , or run so rich you gonna burn stuff up along with your mileage. If you have a Vtec engine use a VAFC, if you have a non Vtec engine use SAFC. Use the FMU with the AFC. You can also look into whats called and injector hack. You best bet though is Hondata. There are also a few other thing you may want to look into that are free but require to purchase things to make them work such as Chips and chip burners.
If its a sohc engine that look in to turboEdit
If its a Dohc look into Uberdata
Both are very much like hondata, but free your going to HAVE to be OBD1 though.
Old Nov 1, 2004 | 05:06 AM
mrspeaker's Avatar
Default Re: new to turbo chips and fmu?? (PissedoffGS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PissedoffGS-R &raquo;</TD></TR><TR><TD CLASS="quote">
Both are very much like hondata, but free your going to HAVE to be OBD1 though.</TD></TR></TABLE>
obd0 ..Use turboedit(free)..
obd1 ..Use Uberdata(free)..or Hondata($$$$$$$$$$)..
dont get a generic chip off ebay because those chips advance timing...And u dont want advanced timing with a turbo becasue you will detonate..
And they also make u run crazy rich..
FMU's are ok for low boost low HP applications..
Same with the vafc/safc ..they are good for low boost
Best thing is to get either uberdata,turboedit,chrome and some 450cc injectors..
But if you plan on having low boost then a fmu or afc will be fine..
Old Nov 2, 2004 | 10:39 PM
Default Re: new to turbo chips and fmu?? (Mrspeaker)
hey
thanks guys but chip burners are impossible to find in new zealand and cost big $$$ to import
i have 450cc injectors installed and big fuel pump
car runs but when i hit boost it cuts out and car dies
so if i install FMU
and install the afc
only them 2 things
will it run boosting pretty good?
or do i need some sort of edited chip?
thanks heaps
Old Nov 2, 2004 | 11:12 PM
DJ_SaNdOz's Avatar
will nobody ship to NZ? shipping freight can't be that much can it? you can get a willems burner on ebay for like $55 US + shipping to NZ.....
PGMFI.org is the best place to research this stuff IMO
Old Nov 4, 2004 | 12:06 AM
Default Re: new to turbo chips and fmu?? (DJ_SaNdOz)
hey yeah i dont really know how to edt chips etc...
but what would this chip actually do?
is it made for a turbo
Old Nov 5, 2004 | 12:31 AM
DJ_SaNdOz's Avatar
That chip will more than likley add *** loads of fuel & timing, and will certainly not be optimized for your setup. I suggest at least reading http://www.pgmfi.org, or http://www.ecimulti.org/uberdata/forum for some info if you have free time. At least you will get a better understanding....You can probably get a better chip from them as well....
97grnrs
Dec 4, 2006 03:26 PM
hahagasdcrx
Feb 2, 2004 11:28 AM
hybridb18
Apr 21, 2003 10:46 AM
freakie
Mar 21, 2003 04:21 PM
