Going turbo?
Old Feb 2, 2004 | 11:12 AM
hahagasdcrx's Avatar
Default Going turbo?
Im about to put a turbo on my B16a Crx and was wondering if it is safe to keep motor stock if boosting to only 8psi? Also want to know what extra parts are needed.... i have a tubular manifold, t3/t4 turbo with downpipe and charge pipe with fmic, also have a tial 35 mm wastgete and greddy BOV. I have a vortech FMU and also a aeromotive FPR and a Apexi VAFC, Crane hi-6 ignition with msd cap. So really my question is , is there anything else i really need?? like check valves or injectors like dsm 450's im already running 310cc's.....
thanx in advance
Old Feb 2, 2004 | 11:27 AM
b16ahybrid's Avatar
Default Re: Going turbo? (90crxzcgasd)
well for one search will answer 99% of your questions.
you can either use the 310's and the fmu with a 6:1 or 8:1 fmu.
Or use the 310's with a 8:1 fmu and the v-afc to fine tune it. or ditch the fmu and get the 450's and run the hack.
I'm using the fmu (4:1) and sfc route for my fuel control, it works good for me. I have relativly low fuel pressure(for using a fmu) and my afr is pretty consistent (12.0:1 +/- .02)
Old Feb 2, 2004 | 11:28 AM
TheShodan's Avatar
Moderator
Wouldn't do more than 7psi on the B16. Need Missing Link or check valves, would also need Ohm resistor box of going anything over 440s. S-AFC would be a start, but can go Hondata or something stronger later if you wish.
97grnrs
Dec 4, 2006 03:26 PM
99hatchboy
Jan 23, 2005 08:35 PM
si_blues
Aug 2, 2004 06:35 PM
mattb16a1civic
Oct 20, 2003 05:35 PM
chirp3rd
Feb 3, 2003 04:56 PM
