Electrical prblms!!! --Passenger Window not working. 95 Accord EX 2DR
Old Oct 31, 2004 | 04:50 PM
JDM_CD7's Avatar
Default Electrical prblms!!! --Passenger Window not working. 95 Accord EX 2DR
Having prblms with my passenger side window not going up/down. Checked switch and changed... same problem. Checked master switch..... same problem. Is there any relays or modulators i need to know of in the door that i can replace or check. And also my interior dome light doesn't work, possibility it can be in the same circuit?
TIA --Hugo
Old Oct 31, 2004 | 06:01 PM
GuestHead's Avatar
Default Re: Electrical prblms!!! --Passenger Window not working. 95 Accord EX 2DR (JDM_CB7)
check the connections inside the door. one of mine got bent when i replaced my door speakers. by bent, i mean the little metal prong thingies inside the little connectors...ull know what i mean when u check it.
Old Oct 31, 2004 | 08:19 PM
JDM_CD7's Avatar
Default Re: Electrical prblms!!! --Passenger Window not working. 95 Accord EX 2DR (GuestHead)
Ok i'll go ahead and check that.
Also what about the dome light is that all connected?
Old Oct 31, 2004 | 08:39 PM
f23accord's Avatar
You might want to check the bulb on the dome light first before trying to look for electrical probs on that
Old Nov 3, 2004 | 06:21 AM
JDM_CD7's Avatar
Default Re: Electrical prblms!!! --Passenger Window not working. 95 Accord EX 2DR (f23accord)
Replaced the bulb same prblm. Checked all the pin connectors in the door and the window still does not roll up/down. The passenger window is only controlled with the drivers side control.
elcapy
16
May 9, 2018 08:22 PM
diyFool
Oct 13, 2008 06:29 PM
my93accord
Jul 21, 2008 02:48 AM
GQej1
Feb 17, 2007 08:22 PM
