95 ex power window problem.
Little help? My passager window doesn't work anymore. I took my car in to get new tint put on and then after the 5 days of waiting I went to roll the windows down and only the driver window went down. The passange one didn't move a bit. Also I checked the fuse and it seems fine. I don't even hear it trying to move.
I've searched and found no helpful topics.
Re: 95 ex power window problem. (GQej1)
Check all your wiring harness connections and double check the fuses...
If still nothing, I would suspect the switch first, and then the motor.
The window motor will be located in behind the door trim panels, inside the door shell where the window itself (in the down position) resides.
Re: 95 ex power window problem. (Miracle)
Thank you. I will try and get that fixed this weekend. I'm sick on only being able to open the driver side window.
after i had tint installed on mine, the weatherstripping around the top of the window sealed my window's shut, i used a butterknife on the outside to open them.
Re: 95 ex power window problem. (Projekt_2nr)
That might be it. The driver side had some trouble at first. But wouldn't i be able to here it trying to roll down. at least a click from the regulator?
i had the same problem in my ej i had to adjust the speakers more up because the window was hitting it
i dont think that might be the problem but you can check that out
or those people that put your tint could fucked up ur window i say u pay them a visit
tried the butter knife with no luck and I switched the fuse with no luck. Looks like the door panel is coming off for me to try and figure out what the F is going on in there.
