4g guru's Here are pictures of unknown parts, please help me identify them
Old Oct 31, 2004 | 10:38 AM
Sinner's Avatar
Default 4g guru's Here are pictures of unknown parts, please help me identify them
all the items outside the box on the left are unknown. please help ID them
Nick
Old Oct 31, 2004 | 10:47 AM
Burlyirishdude's Avatar
Default Re: 4g guru's Here are pictures of unknown parts, please help me identify them (Sinner)
well i know you've got the Hood release Section(that metal piece with the hole). A couple screw caps for the interior( the eclair looking things with the tabs on the end) The under the hood fuse box cover. It looks like that item witha plug is for your headlight region. And those metal pieces look like random parts for the battery plate and maybe for the headlights. Bascially it all stuff for under your hood. hope it helps.
Old Oct 31, 2004 | 10:49 AM
SETI20's Avatar
top triangle: Drivers side mirror adjuster lever cover.
Metal center thing: Hood lock plate
Bottom plastic: Fuse box cover
The rest I can't tell...too small a pic.
Old Oct 31, 2004 | 11:22 AM
CRX Si's Avatar
Default Re: (SETI20)
The plug is a rear defogger and dash light dimmer switch... If you dont need it i would take it off your hands for you...
Old Oct 31, 2004 | 11:23 AM
(Civic_Duty)'s Avatar
Default Re: 4g guru's Here are pictures of unknown parts, please help me identify them (Burlyirishdude)
DieMaster's Avatar
Needs to be About 20% Cooler
most left above bolt is a headlight bulb holder
shiny metal thing in middle os hood releace thing
plastic parts right next to hood thing is E-brake screw cover
big plastic part on bottom is main fuse box under hood lid
part on right side of fuse box lid above it is rear def. swich and **** for gauge brightness
the rest i dont know
Old Oct 31, 2004 | 11:38 AM
Sneaky Ef's Avatar
top left triangle i don't think is inside of mirror cover i think it is were ur hatch strut cnnect to the body, the hatch strut that hold open the hatch if i didn't word that good enough
and i think number 11 on the second pic is the cover that goes around the ignition cylnder (under the bigger cover)
Old Oct 31, 2004 | 05:26 PM
jsooke's Avatar
Default Re: (Sneaky Ef)
Is there a prize for all the right answers???
Old Oct 31, 2004 | 06:54 PM
wompwomp61's Avatar
Default Re: 4g guru's Here are pictures of unknown parts, please help me identify them (tweakedcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweakedcrx &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
you sir do not mess around with answers
Old Oct 31, 2004 | 07:05 PM
Default Re: 4g guru's Here are pictures of unknown parts, please help me identify them (wompwomp61)
i try
Old Oct 31, 2004 | 07:08 PM
i belive that is correct good eye
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sneaky Ef &raquo;</TD></TR><TR><TD CLASS="quote">top left triangle i don't think is inside of mirror cover i think it is were ur hatch strut cnnect to the body, the hatch strut that hold open the hatch if i didn't word that good enough
and i think number 11 on the second pic is the cover that goes around the ignition cylnder (under the bigger cover)</TD></TR></TABLE>
Old Oct 31, 2004 | 07:11 PM
toasterxb's Avatar
those are the correct answers right there
Migs19
Jan 15, 2016 08:24 AM
redline7
Dec 12, 2007 11:46 PM
egredspools
Apr 21, 2007 04:44 AM
SpOoLiNg CiViC
Jan 4, 2007 11:23 AM
Mjfan12
May 4, 2003 06:59 PM
