where does the flasher go?
I need to replace the flasher(the thing that makes the blinkers work) But I dont know where it goes exactly. I checked behind the panel under the steering wheel, but can't find the place it should go. I have a 94 civic dx btw.
Re: where does the flasher go? (Mjfan12)
im guessing you mean the relay, and that is located in the fuse box under the hood, right by the battery, look on the cover of the box, it shows where everything in it is.
Re: where does the flasher go? (leprechan117)
maybe. My blinkers aren't working right now. The problem isn't the bulbs so it must be something else
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leprechan117 »</TD></TR><TR><TD CLASS="quote">im guessing you mean the relay, and that is located in the fuse box under the hood, right by the battery, look on the cover of the box, it shows where everything in it is.</TD></TR></TABLE>
IM pretty sure its to the left of right of the fuse box under your dash.
Re: where does the flasher go? (SleepyDX)
Thanks very much!!! Do I get this from the dealer, or can I get this elsewhere? and what is the proper name or part number?
np.....but im not going back out der to check the part number...sorry. lol. YOu can probly pick on up at any parts store (or at least order one) and IM sure the dealer will have one
