Need a little Help on Engine install Y8 mani Swap.. Pics inside.
Old Oct 30, 2004 | 05:18 PM
drewbie*'s Avatar
Default Need a little Help on Engine install Y8 mani Swap.. Pics inside.
So I finally got my engine in. I have a few questions for the y8 mani swap.
If someone could post a y8 manifold diagram I should be able to get it from there (couldnt find on with search)
This is a 97 Manual Mani.
Red:
Is this a coolent passage? Runs back to the intake manifold?
Blue:
Does this one get capped?
Black:
Need some help?
Not sure where this goes on the IM.
Not sure what this is used for.
Whats this for ? I couldnt find it in the helms and I dont remember where it goes.
Just an interior shot.
Old Oct 30, 2004 | 06:18 PM
EX-T's Avatar
Default Re: Need a little Help on Engine install Y8 mani Swap.. Pics inside. (Drew95eg)
this isn't going to help but I just wanted to say that I got dizzy when I looked at your sideways interior shot.
Old Oct 30, 2004 | 07:23 PM
drewbie*'s Avatar
Up for some info.
Old Oct 30, 2004 | 08:03 PM
Eskay@JDMCircle.com's Avatar
i can take a pic of my stock Y8 and see where that stuff goes if you want..
Update: My vision inspection says, The one on the IM goes into a hose right behind valve cover infront of the injectors, The one beneath the throttle body goes into a coolant line shared with the line that goes into the breather of the valve cover.
Old Oct 30, 2004 | 10:44 PM
drewbie*'s Avatar
TTT
Old Oct 30, 2004 | 11:04 PM
drewbie*'s Avatar
I need to get my car running
Old Oct 31, 2004 | 01:21 AM
SpoolinEK9's Avatar
From: Seattle/Ligonier, WA/PA, United States of Honda
you can cap the blue it goes to catch can or something ont he back of the block. might be the black one tho cant remember.
Old Oct 31, 2004 | 08:19 AM
drewbie*'s Avatar
Default Re: (SpoolinEK9)
bump i want my car running today.
Old Oct 31, 2004 | 08:22 AM
JDMFreak's Avatar
Default Re: (Drew95eg)
red, is a coolent for the fast idle, it should go to the termostate? or near that area there should be a nipple for that passage, and the other end goes to the IACV on the back of the intake and from that point it goes back into the engine...i dont know the name of it but it a long brass piping that runs along the back of the bottom end
Old Oct 31, 2004 | 08:32 AM
JDMFreak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drew95eg &raquo;</TD></TR><TR><TD CLASS="quote">
that end should be connected to your charcoal canister
i was just curious, do you have any back shot of that IM? im looking for any nipples back there, if there isnt any nipples back there and the black one is connect to that sensor i think it called EGR? not 100% sure
Old Oct 31, 2004 | 08:41 AM
JDMFreak's Avatar
Default Re: Need a little Help on Engine install Y8 mani Swap.. Pics inside. (JDMFreak)
http://www.superhonda.com/phot...t=500
Old Oct 31, 2004 | 09:56 AM
SpoolinEK9's Avatar
ya you can cap all that evap stuff if you want to.
Old Oct 31, 2004 | 10:00 AM
Snail Tuning's Avatar
what year of car are you putting the y8 head/intakemanifold into??
[you have alot of things wronge in you pictures.
Blue gets blocked off.
Black runs to th ePCV valve in the intake runners.
The red looks like a coolent line. that water runs through
This is a picture of mine.
also the nipple right next to the throttle cable bracket that needs to run to your FPR not the line from the charcole canaster. you can see this in my picture
take this out its not used in a obd1 car.
the line from the charcole canaster need to go the the throttle body.
this is assuming you are putting this into a 92-95. which it looks like.
Hear is a link with pictures of what sensors go to what wires. incase its not running right.
http://www.imagestation.com/album/?id=4286332563
Modified by Snail Tuning at 6:56 PM 10/31/2004
Old Oct 31, 2004 | 11:41 AM
drewbie*'s Avatar
Default Re: Need a little Help on Engine install Y8 mani Swap.. Pics inside. (Snail Tuning)
Thanks for the info.
This is a 95 civic.. the head is from a jdm d15b..
are you sure you block off both the black and blue outlined nipples? I was pretty sure you only blocked off one... but wasnt sure which... if anyone can verify
Modified by Drew95eg at 1:28 PM 10/31/2004
Old Nov 3, 2004 | 01:43 AM
drewbie*'s Avatar
do i block off both the blue and black outlined nipples?
Old Nov 3, 2004 | 04:51 AM
TouringAccord's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drew95eg &raquo;</TD></TR><TR><TD CLASS="quote">do i block off both the blue and black outlined nipples?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snail Tuning &raquo;</TD></TR><TR><TD CLASS="quote">
Old Nov 3, 2004 | 09:04 AM
LShatchie's Avatar
Default Re: Need a little Help on Engine install Y8 mani Swap.. Pics inside. (TouringAccord)
the black one you connect a PCV then run to the black box on the back of the block. the tube that u are holding goes right next to the map sensor. if you need help with any others hit me up.
Old Nov 13, 2004 | 07:57 PM
drewbie*'s Avatar
Still not sure where this goes.. someone help me out?
Old Nov 13, 2004 | 09:10 PM
Got Spoool's Avatar
on my B16 i believe that goes into the intake mani
Old Nov 13, 2004 | 11:31 PM
Andres-eh2's Avatar
Default Re: Need a little Help on Engine install Y8 mani Swap.. Pics inside. (Got Spoool)
End all of this thread. I know im a nice guy for doing this at 3 am when i have to get up early in the morning.
Old Nov 14, 2004 | 01:41 AM
drewbie*'s Avatar
Default Re: Need a little Help on Engine install Y8 mani Swap.. Pics inside. (Andres-eh2)
That does help. But its a canister from a 95 cx. and teh y8 mani is on a jdm d15b head, so im a bit confused..
here is some of the info for i was looking for. i am missing the two way valve so i guess i need to pick one up.
Modified by Drew95eg at 3:02 AM 11/14/2004
Old Nov 14, 2004 | 11:05 AM
drewbie*'s Avatar
TTT
lunch_box_4_life
Oct 28, 2008 11:29 AM
jiggatone
Apr 22, 2007 07:39 PM
Ron Burgandy
12
Mar 26, 2006 02:28 PM
96 EX
Sep 24, 2005 03:36 PM
yaleforizzle
Jul 30, 2004 09:55 PM
