To All H22/Civic
Hey does your car's shakes when going up to 80mph... mine does... how would you fix that... i'm pretty sure it's not my tires because i got them from my gsr and my gsr ran up to 100 fine... the thing is that when there is people in with and i go up to 80 it runs kool... it's just when i'm driving by myself...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">What axles combo you running?</TD></TR></TABLE>
i'm running the hasport mount and hasport axles...
Try this if you have time
Find the engine speed at 80mph on your tach
Run the same engine speed in a different gear, 3rd and 4th most likely
And see if the problem persists. This should indicate if the shaking is dependent on vehicle speed or engine speed narrowing down possible causes.
Adi
Adi
also mine shook a bit too, but after i got my ecu uberdata p28 with a sick program it runs so much smoother and better. p13 suck *** stock specially with stiff mounts. try to find some one with another program. just a thought thought but tires as they wear out loose their balance so balance them first then ask questions
i've experienced the same thing. at 80 the car shakes real bad but it seems to go away if i sink the clutch or up shift and it doesn't happen in the lower gears at
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23vtecEG »</TD></TR><TR><TD CLASS="quote">also mine shook a bit too, but after i got my ecu uberdata p28 with a sick program it runs so much smoother and better. p13 suck *** stock specially with stiff mounts. try to find some one with another program. just a thought thought but tires as they wear out loose their balance so balance them first then ask questions</TD></TR></TABLE>
not trying to hijack thread but, lets see the bin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyberdx16 »</TD></TR><TR><TD CLASS="quote">
Every tune is different for the reason that every motor is different. Base map + tuning will give you better results than just running his bin. The only thing his bin may do for you is cut the time for partial thorttle and maybe WOT.
But, post that pig
</TD></TR></TABLE>Every tune is different for the reason that every motor is different. Base map + tuning will give you better results than just running his bin. The only thing his bin may do for you is cut the time for partial thorttle and maybe WOT.
But, post that pig
i'll add a little tech to this post on my h22 (sry for hijacking thread in eairler post)
my car does not shake going around 80ish to 100. i'd say its the tires even though you say its not. rotate the tires and see what happeneds.
Post that crap man. There are 100s of h22'ers dying for that bin taht you call god.
yeah... vibrating at certian speeds has to do with something off balance.
ex:
-wheels
-tires
-could be axles alignment due to ride height...
play with ur wheel/tire combo first and see what happens.
ex:
-wheels
-tires
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">no problems at all with my buddies h22 civic... HCP mounts and shortened gator axles... 160+mph with no shaking</TD></TR></TABLE>
Dude, come on now. 160mph+? Wtf are you doing?
there plent of threads about this and most end up saying the same thing.... your problem is your axles, the are the wrong length or the joints are fucked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight[DMD »</TD></TR><TR><TD CLASS="quote">]
Dude, come on now. 160mph+? Wtf are you doing?</TD></TR></TABLE>
racing a f-body.. hit the limiter in 5th (8500 rpms) with a h23 tranny and 225-50-25 tires.. calculated 170mph
builthatch
44
Feb 8, 2008 09:46 PM
Honda_Tengoku
Jun 8, 2004 09:28 PM
Newman
Jul 10, 2002 11:27 PM
