2 wire IACV to 3 wire?
Old Oct 30, 2004 | 12:07 AM
GDM Z28's Avatar
Default 2 wire IACV to 3 wire?
Im in the middle of a LS/Vtec on bost build so im dropping in a SOHC while my cars down. Its a 99 y7 in a 95 eg hatch. Now my question is what do i do about the IACV? ow can i use the obd2 plug on the obd1 engine harness since the obd1 is 2 wire n obd2 is 3 wire. PLEASE help me. TIA!
-Trent
Old Oct 30, 2004 | 04:47 AM
Stoney's Avatar
Default Re: 2 wire IACV to 3 wire? (civicflnum1)
You can't. You need to use an intake manifold from 92+ that has a 2 wire iacv.
Old Nov 4, 2004 | 04:08 PM
Forward Motion's Avatar
Default Re: 2 wire IACV to 3 wire? (Stoney)
hey civicflnum1 i have one for you maybe you could help after your experience, i have a D15b in place of a Y7, (i know i know) using a p2p ECU. i kep getting a code that says manf cntrl veh speed idle speed contrl aux inputs"? I cant seem to get rid of it and the vehicle is tremendously lagging until about 2000/2300 rpms then its just ape ****. it will drive but not what i would consider being road worthy. i'm almost positive that the p2p is a 2 wire IACV monitoring ECU but theres a 3 wire IACV on the Y7 T/B as we used this to simplify and keep it obd2. This is in a 98 4 dr lx. any light you might be able to shed would be appreciated
h22accord101
Mar 3, 2015 12:44 PM
youryanyou
Feb 9, 2011 12:43 AM
three pac
Oct 22, 2010 01:53 PM
hammergunner
Nov 23, 2009 08:24 PM
Rodzknight
17
Feb 27, 2008 09:06 AM
